Old 05-11-2020, 01:18 PM
BCnSTL's Avatar
BCnSTL BCnSTL is offline
Default Just one more driver update for macOS Catalina!
C'mon Avid - dust off the code library one more time! Recompile the 11R drivers for 64-bit only macOS and it should work for several more years. Please?
That'd be great, thank you!
Old 05-11-2020, 04:03 PM
Cowboy Bob's Avatar
Cowboy Bob Cowboy Bob is offline
Default Re: Just one more driver update for macOS Catalina!
Yes please, what he said!
Squaw Creek Road Studio
Bob
Pro Tools Standard (current version)| Avid Eleven Rack ERXP | Sibelius Ultimate (current version)
3.6GHz 8-core 9th-generation Intel Core i9 processor iMac w/40GB RAM | 1TB SSD | macOS Catalina |
Focusrite Clarett 8Pre X | Lenovo i7 ThinkPad | Win 7 Professional | Avid 003 + Rack |
Old 05-11-2020, 04:13 PM
nedorama nedorama is offline
Not sure anyone is left that worked on it at Avid, which presents a struggle. Updating software you've worked on is easy. Updating software that others have worked on that has been carefully documented throughout is easy. Updating software that others worked on without good documentation? Really difficult. I don't know which of the three we're in but guessing #3.
I'd love for them to fix it, but for now running it into my Scarlett 18i20. I have found that the Editor works in 10.15.4 for me - so at least there's that...
Regards,
Ned
Monkey Boy Studios
2013 15" MBP, 16GB, 512GB SSD; OSX 10.15.6; 1.5TB FW800 External
Summit Audio 2BA-221, TLA-50 -->Focusrite 18i20 3rd Gen, Eleven Rack, Pro Tools 2020.5
Plugins, Virtual Instruments, and real ones
Old 05-12-2020, 08:12 AM
BCnSTL's Avatar
The editor does work in Catalina? I thought it did not. That's good news.
Old 05-12-2020, 09:04 AM
It does indeed - I was surprised.
File Type: jpg Screen Shot 2020-05-05 at 2.41.29 PM.jpg (53.6 KB, 0 views)
Regards,
Ned
Monkey Boy Studios
Old 05-12-2020, 01:03 PM
BCnSTL's Avatar
If AVID runs a professional development environment - and I assume they do - then they have decent documentation and code repositories and a competent developer could update the drivers with some nominal effort.
Did you just install the 11R Editor or did you have to install drivers as well?
Old 05-12-2020, 01:38 PM
Drivers not installed, just the editor.
Regards,
Ned
Monkey Boy Studios
Old 06-29-2020, 08:11 AM
ac30fan's Avatar
ac30fan ac30fan is offline
Every update of PT wipes out 11R editor for me. I get the MIDI engine error & 11R not available in PT Windows pull down menu.
Seems that every MacOS update restores it
Bummer because I update PT more frequently than OS
2019 iMac 27" 5k Retina
3.6 Ghz 8-Core Intel Core i9
Mac OS 10.15.5 / 60GB RAM
UAD FW Apollo Duo (Thunderbolt Card)
PT 2020.5
Eleven Rack FW v2.00.1 / Software 1.2.13
Old 07-01-2020, 05:03 PM
ac30fan's Avatar
I get the MIDI engine error & 11R not available in PT Windows pull down menu. Seems that every MacOS update restores it.
YEP, as suspected: Updated Catalina to 10.15.5 and MIDI ERROR message is gone, the Editor app launches, and 11R appears in PT in the Windows pull down.
Something buggy in AVID's PT releases is messing up 11R
PT 2020.5
Old 07-02-2020, 09:18 AM
BCnSTL's Avatar
I'm curious - does rig-embed work? I had thought that only worked when the 11R was your primary audio interface.
Eleven Rack Compatibility with MacOS Catalina guijacobucci Eleven Rack 62 08-21-2020 11:29 AM
PT and Latest macOS Catalina (10.15.4) rinky Pro Tools 2020 3 04-29-2020 01:12 PM
PT 12.5 and macOS Catalina johnbarnesiii macOS 12 12-20-2019 03:02 PM
Can EuControl 19.9.0 be used with MacOs 10.15 Catalina? hanksinclair Artist Series 2 12-09-2019 10:54 AM
macOS 10.15 (Catalina) and Avid Products Avid Technical Alerts 0 10-07-2019 11:11 AM
