Go Back   Avid Pro Audio Community > Legacy Products > Pro Tools 2020
Old 05-09-2020, 02:06 PM
spymonsayz spymonsayz is offline
Default Loop play is not working
I don't know if anyone is having the same issue, but when I select an area and try to play it in a loop, it ignores it and simply continues forward.
Quick punch is not enabled
No Tracks are in record mode
Tried pre/post roll on off
On a Windows system...
I am at wits end....
Is anyone else having this issue?
Old 05-09-2020, 02:13 PM
Default Re: Loop play is not working
Ok Never mind...I see my "Link Timeline and Edit Selection" needed to be selected....trying to delete this post but I can't see how
Old 05-10-2020, 12:41 AM
cwsand's Avatar
cwsand cwsand is offline
Might as well keep it up - someone else could have the same issue.
Help Us Help You
Chris
Pro Tools 2024.3
Focusrite LS56
Focusrite Pro40 (3)
Slate Digital VRS8
Analogue Tonebuss 24 Channel
UAD-2 OCTO Core Accelerator
UAD Volt 2
macOS 10.15.7
32 GB DDR4 RAM
NVIDIA GeForce GT 740 2 GB
Error: "Pro Tools cannot be put online while in loop play or loop record mode." msg6794 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 8 11-12-2016 06:09 AM
Notation view edit while in play cause play to stop working. soybalm Pro Tools 10 1 04-18-2013 11:11 AM
navigating during Loop play without removing the loop remusjacobs Pro Tools 10 1 08-10-2012 06:11 PM
