Go Back   Avid Pro Audio Community > Pro Tools Hardware > Third Party Interfaces
Old 04-26-2020, 03:28 PM
dg27's Avatar
dg27 dg27 is offline
Default XLR versus TS
I just bought a PreSonus 26c interface to replace my MBox3.
I'm connecting the interface to a PreSonus BlueTube preamp.
When connecting the inerface to the preamp does it make any difference whether the connection to the from the interface is TS or XLR?
I've always used an unbalanced 1/4" TS Male to 3-Pin XLR female audio cable.
Would it be better to use an XLR M to XLR F microphone cable?
(I have to replace the XLR to TS cables I was using because they're too short .)
Dell Studio XPS 9100; Win 10 Pro 64X, i7 960@3.2GHz, 24 GB RAM, Samsung 840 Pro 512 GB SSD boot, Samsung 850 Pro 256 GB dedicated audio drive, Samsung 860 EVO 1 TB PT archive drive, 2X WD Caviar Black 2 TB storage drives, NVIDIA GeForce GTX 960 (EVGA), 2X 24" HP Dreamcolor LP2480zx Professional Display
Pro Tools 2020.3, PreSonus 26C, PreSonus Bluetube v2, PreSonus HP4, JBL LS305 monitors, Sennheiser HD 650 headphones
Old 04-26-2020, 03:40 PM
JFreak's Avatar
JFreak JFreak is online now
Default Re: XLR versus TS
TS is unbalanced (2-wire) and XLR is balanced (3-wire) so obviously you better use balanced connections.
Janne
Old 04-26-2020, 04:05 PM
dg27's Avatar
Thanks. I was confused because I always used TS --> XLR with the MBox. I've attached a connection diagram.
It's a bit of a PITA because the inputs on the MBox were front and rear; on the PreSonus they are front only, which means I have to go around to the back to connect to the preamp. That's why I have to replace my cables.
File Type: pdf 2020_0426_interface-preamp-hp amp connection.pdf (227.3 KB, 0 views)
Old 04-26-2020, 04:06 PM
JFreak's Avatar
From that pic you cannot tell if it is TS (2-wire) or TRS (3-wire)
Janne
Old 04-26-2020, 04:12 PM
dg27's Avatar
Thanks for your help.
It accepts either (like a guitar jack or an XLR mic cable). Maybe you can tell on this.
It was the same type of connection on the MBox and I always used TS out of the MBox and XLR into the preamp.
Old 04-26-2020, 04:15 PM
JFreak's Avatar
That looks like a Neutrik combo XLR/TRS connector so whatever you choose you should have balanced (3-wire) option
Janne
Old 04-26-2020, 04:24 PM
dg27's Avatar
Yes--that's what it is.
This is my fault. I was confusing TS with TRS.
I just checked what I have now: it's like this:
Hosa Technology HXS-005 Balanced 3-Pin XLR Female to 1/4" TRS Male Audio Cable (5')
The question I should have been asking is whether the above is fine or whether I should be using this instead:
https://www.bhphotovideo.com/c/produ...lite_4000.html
Old 04-26-2020, 04:25 PM
JFreak's Avatar
You usually use XLR-XLR cables with microphones, but whatever 3-wire balanced cable you use does not make a difference
Janne
Old 04-26-2020, 04:27 PM
dg27's Avatar
OK. Thanks.
This is what I have now only shorter.
https://www.bhphotovideo.com/c/produ...3_Pin_XLR.html
Old 04-26-2020, 04:29 PM
JFreak's Avatar
Yes, electrically it is just the same. However XLR cable can lock to your gear but TRS plug cannot. I would take XLR any day, but whatever works for you.
Janne
7.3 versus 7.1 on G4? Moz 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 4 02-02-2008 09:45 AM
Mac G4 versus G5 versus Windows XP progress88 General Discussion 22 09-08-2003 09:45 AM
M-149 versus? DougP General Discussion 15 10-03-2000 06:38 PM
OS 9.0.4 versus 8.6 dodged forgottenn Pro Tools TDM Systems (Mac) 1 09-02-2000 07:21 AM
