Go Back   Avid Pro Audio Community > Pro Mixing > Avid S6
Old 04-04-2020, 01:40 AM
Mishabou Mishabou is offline
Default Master module Appset blank
While waiting for my S6 software update, i installed PT 2020.3 and now all my appsets are gone.
Saw a post related to this issue and it was recommended that i LOAD the PT19 appset, i only see version 10/11/12/18/20Mac, tried all of them and none worked. Where can i find 19Mac ?
I'm using WS v3.5 and PT 2020.3.
Thanks
Old 04-04-2020, 04:18 PM
creativecontrol's Avatar
Default Re: Master module Appset blank
Greetings,
Start here and let me know if this works:
http://avid.force.com/pkb/articles/e...vid-S6-Support
If you are using the Pro Tools 2018 or later software with S6 software v3.7 or lower you will need to manually install the latest AppSet XML files, available here. Copy the file to a USB flash drive and connect the drive to one of the rear USB ports on the Master Touch Module. Log in to the Administrator account (default password is "password"), decompress the .ZIP file, and run the enclosed .EXE file.
http://resources.avid.com/SupportFil...atch_3_7_0.zip
Jeff
Jeff Komar
Solutions Specialist, Pro Audio
S6 FAQ
Old 04-04-2020, 05:38 PM
Hi Jeff,
I did follow those steps before posting and it's not working.
All the soft keys are blank.
Old 04-04-2020, 05:56 PM
Standby, sending you a PT19Mac XML...
Jeff Komar
S6 FAQ
Old 04-04-2020, 06:04 PM
Here you go. Let me know.
https://www.dropbox.com/s/2kwg9ut4b4...19Mac.xml?dl=0
https://www.dropbox.com/s/3bu6g3itpr...20Mac.xml?dl=0
Jeff
Jeff Komar
S6 FAQ
Old 04-04-2020, 06:22 PM
Thanks Jeff for the Appset
Btw, do i need to install Eucon Workstation Unified 20.1 and Eucontrol Appset 1.2 ?
As mentioned my S6 M10m is 3.5 and Mac Pro is running WS 3.5
Old 04-04-2020, 06:32 PM
Just tried loading 19Mac.XML and got the same error ''Attempted to load invalid appset or appset that does not match the focused app type..."
Old 04-04-2020, 06:33 PM
Are you loading it while Pro Tools is focused?
Jeff Komar
S6 FAQ
Old 04-04-2020, 06:40 PM
Yes, PT is focused when loading the appset
Old 04-04-2020, 06:43 PM
Thanks. I need to confer with Eddie and see if this is even feasible pairing S6 software from 2016 with PT from 2020. Standby...
Jeff Komar
S6 FAQ
EQ and DYN not displaying on knobs or Master module pikejono Avid S6 9 08-02-2019 06:33 AM
Master Module Won't Boot hixonjames Avid S6 6 02-09-2018 12:01 PM
Best way to wire footswitch to Master Module for talkback ? WildHoney Avid S6 3 09-18-2017 07:23 PM
S6 not recognizing any modules, including master module polyh3dron Avid S6 4 06-30-2016 06:14 PM
Master Module FAN NOISE rcutz Avid S6 11 07-29-2015 06:39 AM
