Go Back   Avid Pro Audio Community > Pro Tools Software > Pro Tools 2020
Old 04-01-2020, 05:39 AM
arche3's Avatar
arche3 arche3 is offline
Default can I rename 2019.10 and install 2020 to have both?
possible to have both installed?
Old 04-01-2020, 06:04 AM
reichman's Avatar
reichman reichman is offline
Default Re: can I rename 2019.10 and install 2020 to have both?
I've done this with countless Pro Tools installations and it has worked. I'm sure it will with PT 2020, too. A developer would point out that the cleanest way to switch between versions would be to trash preferences each time you switch. But try it out.
Nathaniel Reichman
Supervising Producer – Re-recording Mixer
Dubway Studios
Old 04-01-2020, 06:15 AM
JFreak's Avatar
JFreak JFreak is offline
trashing prefs mainly forces PT to rebuild plugin cache which may help in anomalies should there be significant change between stock plugin versions
Janne
Old 04-01-2020, 06:30 AM
arche3's Avatar
thanks guys!
Old 04-01-2020, 06:46 AM
Tim R. Tim R. is offline
Just head the warning when installing 20.3 (or do it first). You need to copy the workspace pref file to a backup location and swap it out to use your 19 version.
Tim Reisig
System 1: Pro Tools Ultimate 2020.5, HD Native TB, HD OMNI, S3/Artist Transport/Eucontrol 20.6, Rosetta 800 w/XHD card
Mac OS 10.14.6, 2018 Mac Mini 3Ghz i5, 32Gig RAM
System 2: Pro Tools 2019.12 (no Hardware), Mac OS 10.14.6, MBP (Retina 13in, Early 2015, 3.1Ghz i7, 16Gig RAM)
Old 04-01-2020, 08:22 AM
arche3's Avatar
Oh... I didn't do that. But its on my laptop not my studio computer. Ill make sure to do that for my studio computer.
Sent from my SM-G986U using Tapatalk
Old 04-01-2020, 08:31 AM
arche3's Avatar
Tried opening 2019.10 after I used 2020. 2019.10 said it is backing up workspace and creating a new workspace. Will see what happens when I go back to 2020 again.
Old 04-01-2020, 09:21 AM
arche3's Avatar
going back and forth between 2019.10 and 2020 works fine. I just deleted preferences with the Peter Gates app between each switch.
the database thing only seems to come up going from 2019.10 to 2020.
I didn't bother to backup that workspace database each time. I am not sure what it does?
basic folders tracks go away. routing folder tracks turn into Aux input as expected.
Plug-ins/PT 2019 (2020) Installation Question TDTPost Pro Tools 2019 4 03-20-2020 02:25 PM
New Avid Link 2020.1 - launched today 1/16/2020 marianna Licensing & Accounts 8 01-16-2020 11:43 PM
2019.10 Won't Install DrBiscuits Pro Tools 2019 17 11-15-2019 08:06 AM
Install pro tools 2019.10 over 2019.6? Clarkston Guy Pro Tools 2019 6 11-01-2019 08:12 AM
PT 2019.6 Install Problem lgreen100 Pro Tools 2019 8 08-24-2019 08:05 PM
