Go Back   Avid Pro Audio Community > Pro Mixing > Avid S6
Old 03-31-2020, 01:43 PM
Nico Berthold Nico Berthold is offline
Default Spill Folder Tracks
I`ve just been playing around with 2020.3 a bit and was wondering if you can spill folder tracks, kind of the way you can spill VCAs.
In the track type menu I see folder tracks, but so far didn`t find a spill function.
Anyone had more luck?
thanks,
Nico
Old 03-31-2020, 01:53 PM
creativecontrol's Avatar
creativecontrol creativecontrol is online now
Default Re: Spill Folder Tracks
Greetings,
Initial support for Folder Tracks in EUCON will be coming in April. This includes opening and closing of folders, siblings and children. I’ll defer to Eddie on future capabilities like Folder Spill, as I know it’s not a trivial implementation.
Jeff
Jeff Komar
Applications Specialist, Pro Audio
Old 03-31-2020, 02:32 PM
Hi Jeff,
wouldn`t opening and closing of folder be the same as spilling?
At least, if I am understanding you right, it would bring everything that`s inside the folder on the console. That would be a great first step
Nico
Old 04-01-2020, 07:35 AM
EddieJones's Avatar
The 20.4 release at the end of April will do this: On a folder track strip on the surface there's a new Open/Close button, this operates the same as the one on the track in PT. On the Tracks screen on the Master Module there's a new category called Tracks and a new button next to Inp, Solo, Mute, Rec etc. to Open and Close them. On the Master Module the Type button (left of the softkeys) now shows Folder Tracks and these can then be 'spilled' onto the surface or into a spill zone. This is the Folders not the contents. In the preferences there are 3 new options next to the Show Hidden Tracks options to allow Folder Child tracks to be shown in banking, layouts and spill zones even when the Folder is closed.
So whilst there is no spill contents of X Folder into a spill zone at the moment, working in backing mode will work the same as the PT Mix/Edit window, hiding and showing folder.
The feature release after 20.4 will then have full Folder Spill similar to VCA spill.
Eddie
Old 04-05-2020, 11:45 PM
bobdodgy bobdodgy is offline
That's good to hear - loving it!
I dont suppose ICON - DCommand etc users will be in luck?
Old 04-06-2020, 10:45 AM
EddieJones's Avatar
No the Icon wont be getting the S6 style Folder Tracks features...its a lot of work just for EUCON surfaces.
Old 04-06-2020, 11:42 PM
ah well..
thanks Eddie.
B.
Old 04-28-2020, 04:35 AM
innenhofstudios innenhofstudios is offline
so the only difference to VCA is that Folder have a post-fade behaviour.
VCA Spill gets then some sort of unnecessary, right ?
Best René
www.innenhofstudios.at
Folder tracks with D-Command. Spill? audioluche ICON & C|24 6 04-06-2020 11:49 AM
nudging tracks in VCA spill broken since Eucon 2019.5 update yoerik Avid S1, S3, Dock and Control 1 06-10-2019 10:09 AM
PT Control Tracks View & VCA Spill is now here! Tom Graham Avid S1, S3, Dock and Control 26 05-21-2017 08:15 AM
spill from analog outs to record tracks (when rec) bluerockgod Pro Tools TDM Systems (Mac) 4 02-20-2006 09:04 PM
Mbox spill from analog out to record tracks bluerockgod 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 4 02-19-2006 05:55 PM
