Old 03-31-2020, 10:17 AM
massivekerry massivekerry is offline
Default Any way to Import a Page of SoftKeys from an older AppSet?
I've been looking through the Eucon documentation and Support Pages without avail, so I'm turning here.
I'm hoping that there is a way to import a "Page" of SoftKeys from an older version of an AppSet.
Specifically, I use Pro Tools. 10 years ago, I bought an Avid Control (Well, MC Control) and programmed 2 pages (135, 136) of custom SoftKeys that I have modified and rely on, to this day. Basically, every time a new AppSet is released for PT, I copy and rename my old User Set to match the current version (ie - "Pro Tools 19Mac.xml")
In the intervening 10 years, the ways that Softkeys are used in Pro Tools has changed, to accommodate the newer hardware and new PT features. A lot of those new pages seem well laid-out, plus there seem to be extra (new) pages available for User Softkeys. I'd really like to take advantage of that, but I also would really like to not have to re-program my 2 pages of existing Softkeys from scratch.
So, what I'm looking for the answer to is - Can I (somehow) import the contents my old/existing SoftKey Pages 135 and 136 into the new default PT Appset (for 2020) in the current Pages used for User SoftKeys (146, 148, 149)?
The SoftKeys Editor in EuControl lets you Import different Appsets, but does not seem to have a function that allows you to import parts of them.
Old 04-01-2020, 07:37 AM
EddieJones's Avatar
Default Re: Any way to Import a Page of SoftKeys from an older AppSet?
Sorry no easy way. The file is an xml so you can copy and paste the text from one file to the other if you have an xml text editor.
Old 04-01-2020, 11:44 AM
Thanks Eddie. That's about what I expected. Any suggestions on finding the correct set of lines to correspond to the relevant pages? Hoping that I can gran the whole chunk for a page, copy it to a new doc, and experiment with cut-pasting.
Old 04-01-2020, 12:15 PM
EddieJones's Avatar
Open them side by side and then search for your page, it should be quite easy to see what to do.
Merging Appset files its2loud Avid S6 2 10-05-2018 08:11 AM
Appset dez811 Avid S1, S3, Dock and Control 5 10-07-2017 11:03 AM
Toggle Mix/Edit Window on Page One of Softkeys .. john1192 Avid S1, S3, Dock and Control 1 06-29-2017 07:07 AM
Import audio Page is frozen bassace123 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 3 12-28-2008 06:31 PM
Can I import from newer version to older? grateful 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 12-12-2008 07:49 AM
