Old 02-10-2020, 10:48 PM
pherzfeld pherzfeld is offline
Default Gui Lag in 2019.10 on OS 10.13.6
Hey everyone. Ive actually experienced this issue over the last few versions of Pro Tools, and on Sierra as well as High Sierra. Often (not always) when I zoom in on a at some point (zoomed in pretty close) Pro Tools begins to lag. If I try to zoom out it will zoom out 1 frame every 5 seconds or so until it gets to a certain point and begins to work normally. Sometimes restarting Pro Tools helps, sometimes not.
Any advice?
2013 Mac Pro
3.7 GHz Quad-Core Intel Xeon E5
64 GB 1866 MHz DDR3
AMD FirePro D300 2048 MB
Lynx Aurora x2 with via thunderbolt
Avid Artist Mix x2
Ipad Running Pro Tools Control
G Drive Thunderbolt Hard Drive
Old 02-11-2020, 04:32 PM
cwsand's Avatar
cwsand cwsand is offline
Default Re: Gui Lag in 2019.10 on OS 10.13.6
What Pro Tools version are you running?
Help Us Help You
Chris
__________________________________________________
Focusrite Liquid Saffire 56
FocusritePro 40 (2)
TCE Studio Konnekt 48
Gigabyte GA-Z170-HD3P / i7 6700K 4.1 GHz / 32GB Crucial DDR4
macOS Catalina 10.15.7
Pro Tools HD 2021.10
Old 02-11-2020, 04:36 PM
I knew I forgot something....
2019.10. This issue has persisted through multiple versions though
Old 02-11-2020, 10:54 PM
cwsand's Avatar
Well you'd think with a computer that powerful you wouldn't have lag issues. Maybe a plugin is causing it. Have you tried opening a session with plugins disabled?
Help Us Help You
Chris
FocusritePro 40 (2)
Old 02-12-2020, 12:44 AM
Meads Meads is offline
How many screens are you using, and what resolution are they running?
iMac Pro
- MacOS 10.14.6
- Pro Tools U HDN 2019.6
- Avid HD Omni + HD I/O 8x8x8
- C|24 | S3 | Dock
Old 02-12-2020, 09:00 AM
Screens....you may be on to something here...
Two screens - Main screen over hdmi running 1080p - second monitor running on DVI to display port adapter (generic, not apple) running 1080p.
Old 02-12-2020, 09:05 AM
2x 1080p shouldn't be an issue though. But I noticed GUI lag with two or more 4K or Ultrawidescreens hooked up.
But still, wouldn't hurt to check what happens, when you disconnect one of the screens.
Another source for GUI lag I tracked down is using a screen sharing app called Remotix. It's basically the same as TeamViewer, but it seems to mess with something that makes PT trip.
iMac Pro
- MacOS 10.14.6
- C|24 | S3 | Dock
Old 02-12-2020, 09:06 AM
JFreak's Avatar
JFreak JFreak is online now
Can you please verify you are running displays on separate GPU's or by any chance both on one? You can get this information from the Apple menu, About This Mac, System Report, Hardware, Graphics/Displays. In case both displays share same GPU and you have a free GPU doing nothing, just swap the DP adapter to another TB slot and try again.
Janne
Old 02-12-2020, 11:38 AM
Both displays are running on the first card. I just swapped the second monitor to the second GPU. Let’s see if that helps. Good thinking!
Old 02-14-2020, 03:13 PM
Experienced the GUI lag last night. Unplugged the second monitor all together and didn't solve the problem. Hopes dashed....
Workspace Borked 2019.10 and 2019.12 KMcK Pro Tools 2019 0 01-17-2020 03:09 PM
2019 iMac vs 2019 Mac Pro Peterjk Pro Tools HDX & HD Native Systems (Mac) 7 01-14-2020 01:23 AM
Install pro tools 2019.10 over 2019.6? Clarkston Guy Pro Tools 2019 6 11-01-2019 09:12 AM
Updating from 2019 .5 to 2019.6? ihate100bees Pro Tools 2019 13 07-04-2019 09:30 AM
