Old 01-30-2020, 07:10 AM
luca.cremona luca.cremona is offline
Location: via G. Boccaccio, 7, 21040, Venegono Inferiore (VA), Italy
Default Record an orchestra
Hi everyone,
I apologize in advance for the possibly stupid question.
I have to record an orchestra in a small recording studio, so I will record each section separately. Since I have to record 10 songs, and I'd like to use the same setup for the pro tools project (routing, plugins, etc.), my question is: should I use the same project and record all the songs one after the other or it wold be better to create a project for each song? If so, is there a way to, after processing the first song, apply the same parameters (routing, plugins, etc.) to the other projects?
Thanks
Luca
Old 01-30-2020, 08:32 AM
Default Re: Record an orchestra
Either way works for an orchestral date. I would save after each and every take(something you may already do) and save a copy whenever time permits(to another drive).
If you decide to do a separate session for each piece, when the first one is done, Save As Template(uncheck the option to include media) and then do the rest based off the same template. The biggest decider in this is probably time. If someone(producer, conductor, etc) is a clock watcher, working in a single session will be faster(no time waiting for closing and opening sessions)
Old 01-30-2020, 08:41 AM
Albee1952, thank you.
In case I work on a single session, is there a way to "reset" the bars count at each marker? Assuming I set a marker at the beginning of each song, I'd like to have the bar count starting from 1 for each song.
Thank you
Luca
Old 01-30-2020, 08:45 AM
JFreak's Avatar
JFreak JFreak is offline
Also if you need to transfer one song somewhere recording everything on one session is a big time waster
My take on this would be having one "master session" with all audio; obviously in this case all in separate takes, but anyhow consider it as one big live gig. Just remember to backup the master session with all audio once everything is recorded.
One can always split songs later. No need to know everything you are going to do before you get started.
Janne
Old 01-30-2020, 05:20 PM
Thank you
Luca
This won't be possible within a single session. Just drop markers so you can find starting points for each "piece". As JFreak said, you can split things out after the tracking is done(or refer to my first suggestion for using a Session Template and track each piece in its own session)
Old 01-30-2020, 06:14 PM
JFreak's Avatar
Actually it is, in case all of the material share the same tracks and all. Group everything, create playlists, start each song (take) from zero -- done.
Janne
Old 01-31-2020, 10:20 AM
docric docric is offline
Seems unlikely that each song would share the same tempo/meter, no?
-C' ya'
Rick
MacPro 6,1; 12 core; 64 Gb RAM; 1 TB Samsung 970 Pro w/ adapter & heatsink; OSX 10.14.6
PT 2019.12.0 Ult.
Burl MS / PT Dock/ Avid S1/2x iPad Air2/ Avid|Control
Old 01-31-2020, 10:27 AM
JFreak's Avatar
Orchestral music is rarely performed against constant tempo. It fluctuates, which means using seconds in main meter. I believe seconds are same length for each song, aren't they
Janne
Old 01-31-2020, 10:41 AM
Touche' !
Wasn't trying to be a smart-ass at all (I probably failed)... but OP did say this:
... Assuming I set a marker at the beginning of each song, I'd like to have the bar count starting from 1 for each song.
Bar count in PT session- given the idea to "nest" each song in a PT playlist using matching tracks in the same "master" session- would be dependent on meter/tempo in the session wouldn't it? I understand that orchestral music tempo varies quite often... I'm just trying to figure out how I would do this myself. I've always created separate sessions for each song in the past when I've found myself in this situation.
-C' ya'
Rick
PT 2019.12.0 Ult.
Old 01-31-2020, 10:47 AM
JFreak's Avatar
Sure. There is only one tempo map in a session so if you need bars|beats (and want to start each song from zero seconds) you have no other option than having each song in its own session.
Of course, if it isn't too awkward and you really want to keep all your stuff in the same session, you could start first song from beat 001, second song from beat 101, and so on. But in the end it is more trouble than splitting the stuff into multiple sessions.
Janne
What's the best way to get an orchestra in the mix? SWBoatman25 Tips & Tricks 2 01-12-2016 01:08 AM
HD for orchestra library? villagesound Pro Tools TDM Systems (Mac) 5 03-30-2009 10:29 PM
Garritan Personal Orchestra Vs Symphonic Orchestra Re_Org General Discussion 0 08-02-2004 06:57 AM
Mixing with Orchestra vogue Tips & Tricks 1 06-09-2004 05:13 PM
orchestra goeperd 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 08-08-2000 03:28 PM
