Old 01-21-2020, 05:32 PM
Cacov's Avatar
Cacov Cacov is offline
Default Help configure PT with two Apogee Symphony I/O via ThunderBridge
I've been unable to get any sound from a second Apogee Symphony I/O I added to my system via ThunderBridge 64.
I followed Apogee's instructions (on connecting a second Symphony I/O unit to a ThunderBridge 64), and used the Loop Sync feature to make the second one clocked correctly.
I can make it work on Cubase with no issues, I can route tracks to any output from either Symphony unit, but there's no way I can get any sound from the second unit with Pro Tools.
I already re-configured all the I/O settings on Pro Tools, new session from scratch, etc... and even though the I/O settings automatically recognises both units and assigns I/O matrix accordingly, when I route to the second Symphony unit, nothing happens.
Please help
PT 2019.12
macOS 10.13.6 High Sierra
Mac Pro Late 2013
Apogee Symphony I/O 16x16 (primary)
Apogee Symphony I/O 2x6 (secondary)
Apogee Symphony 64 ThunderBridge
macOS Mojave | Avid Pro Tools Duet, Apogee Groove & Symphony I/O | Pro Tools Studio 2022
Sound Engineer | Non-Avid Employee
Old 01-21-2020, 07:13 PM
Default Re: Help configure PT with two Apogee Symphony I/O via ThunderBridge
When you look in Pro Tools what exactly do you see for the IO paths? Screenshot time..
What exact modules do you have in each chassis? Your signature is a bit confusing. If you just one 16x16 module in one chassis why not add the 2x6 module to the same chassis? Why does it need to be in a separate chassis?
Only Pro Tools HD/Ultimate using a DigiLink interface can access more than 32 inputs and outputs. For any other systems Pro Tools only works with the first 32 IO. I suspect the issue here is what does ProTools thinks the first 32 inputs and outputs actually are. If you can you need to map all the IO in Mastero to be below the 32 IO limit. I'd just contact Apogee support of your questions are any deeper.
Old 01-21-2020, 08:25 PM
Cacov's Avatar
Thank you very much for your input, and the PT 32 I/O limit reminder.
I have a chassis with 2 8x8 cards and a second chassis with a 2x6 (that's why I had to use 2).
I think you nailed the problem on first suspicion. I first tried to clear all ADAT and AES digital IO from the IO matrix on Pro Tools with no luck (second Symphony still out of 32 range, no matter what I discard.
Then, on Maestro I tried to remap all the Analog IO to the first 32 "slots", but it seems I'm stuck with a rigid matrix I cannot modify at will. The main problem seems to be that the Symphony 64 ThunderBridge forces the second unit to the 33-64 range, on a separate stream, and I have found no way to change that.
I'll try to get away like this, take a look at screenshots please:
https://snipboard.io/GQRmTs.jpg
Tnx
Old 01-21-2020, 08:36 PM
Cacov's Avatar
It worked! Thank you very much Darryl
Apogee Symphony I/O 8x8 + 8MP including Thunderbridge Metod Buy & Sell 0 06-05-2017 03:00 AM
Apogee Thunderbridge for Avid HD I/O? producerdna macOS 88 03-27-2015 11:32 PM
Error 6101 in Pro Tools 11 and Symphony IO Thunderbridge dbdmusicproductions macOS 5 12-20-2013 08:30 AM
Pro tools HD 10 with Apogee Thunderbridge?? producerdna Pro Tools HDX & HD Native Systems (Mac) 0 05-30-2013 01:34 AM
Apogee Symphony, symphony 64, motu 128, 3u rack case chrisgil Buy & Sell 1 02-18-2013 10:48 AM
