Old 12-30-2019, 11:33 PM
bricedav bricedav is offline
Default New Mac Pro (7.1)
Hi, I will receive my new Mac in February
I have an HDX Card, and 2 Avid Interfaces
Does anyone already have received his Mac Pro and made full test of Pro Tools and if the HDX Card works with it
Thanks!!!!
Old 12-31-2019, 07:02 AM
lucienpalmer lucienpalmer is offline
Default Re: New Mac Pro (7.1)
According to Apple:
“Avid can enable support for up to six HDX cards, resulting in more IO, increased voice count and two times the real-time DSP processing than any other system can achieve in Pro Tools.”
Pro Tools Ultimate, HDX3 & MTRX + HD MADI
7,1 MacPro, 3.2GHz 16-core, OSX 10.15
S6 M10 16-5, Dolby Atmos RMU
AJA Kona LHi, Sync HD
www.ToolshedAudioPost.com
Certified for Dolby Atmos Home Entertainment
Old 12-31-2019, 07:43 AM
Southsidemusic's Avatar
I don’t think thats implemented yet though. Maybe later next year but the promised doubled voice counts may or may not be there yet either.
Best Regards
Christopher
South Side Music Group
WEBHOME
Old 12-31-2019, 07:49 AM
I was talking about the compatibility with the new Mac Pro (7.1), is anyone has already tested it with Pro Tools and an Avid Card HDX...?
Old 12-31-2019, 07:53 AM
Yes sorry, it works great with 1 and 2 HDX cards. No issues as our co-production team got theirs already and we get our 2 New Mac Pro 7.1 28core jan 7th.
Best Regards
Christopher
WEBHOME
Old 12-31-2019, 07:58 AM
Right, that was a quote from the Apple press release for the 7,1 on their website. So three HDX cards definitely work now, and Avid will add support for at least 6 to work later.
Old 12-31-2019, 08:23 AM
Awesome!!!! Thanks for your answers, I’m glad it works!!
Old 12-31-2019, 08:21 PM
Studio Dweller Studio Dweller is offline
Just upgraded from a 2008 Mac Pro, PT 10 HD3 Accel to a 2019 Mac Pro (16-core), Pro Tools 2019.12 HDX. It’s been a surprisingly smooth transition so far. I’ve only just finished updating the bulk of my plugins so I haven’t run the system for an actual session yet. Pleasantly surprised to be able to continue using my Control 24 via the Neyrinck V-Control Pro software. So far, the only issue I’ve found with it is not being able to change automation modes on each channel even though it says it should work. All things considered, this has been pretty smooth, especially considering how far behind I was and being forced to jump into Catalina.
Larry
Cellar Dweller Productions
PT 2020.3.0 HDX, HD IO 16x16 analog, 192 I/O, Control|24
Mac Pro 2019 16-core, 96GB RAM, OS 10.15.2
Old 12-31-2019, 11:00 PM
jesele jesele is offline
Hi all, a happy new year from Gotland, Sweden.
What slot did you put the HDX card in and did you need an adapter for the power cable?
Like the Belkin kit 6->8 pins. (One would think Avid will make new cables so that no adapter is needed eventually. 2023 )
Waiting for a 16-core, 96GB RAM, 2 TB SSD with basic graphic card.
Have one HDX-card with two HD/IO interfaces.
Also, anyone tried to put the iLok in the internal USB-port?
That would be great if it works.
Jesper
Mac Pro 7,1 16-core, 96 GB, OS X.15.4, HDX 1, HD i/o 8x8x8 + HD i/o 16 digital + Metric Halo ULN 8 3D + RME Fireface 800
http://vicc.se/studio-alpha/
http://jesperelen.com
Old 01-01-2020, 07:57 AM
I assume that there’s no benefit of putting the HDX card in a 16X slot so I put it in slot 6 (8X, two slots below the Apple IO card) and yes, you will need the adapter for the power cable. I bought the Belkin set of adapter cables directly from Apple and it’s the one labeled “Cable set 3, PCIe Aux Power Cable 6-pin to 6-pin”. I have a 16x16 analog HD IO and a 192 IO (16 analog in, 8 digital out) connected to it.
I haven’t tried the ilok in the internal USB port.
Larry
