Go Back   Avid Pro Audio Community > Pro Tools Software > Pro Tools 2019
Old 11-11-2019, 07:32 PM
DMAC DMAC is offline
Default MIDI notes sent to external keyboard are triggering early
MIDI tracks being routed to my Yamaha MOXF are triggering about 210 ticks early on playback. Not a problem when recording the tracks from the same keyboard. Even if I over-quantize the MIDI track it still plays back early. When the same track is sent to an internal soft synths the playback is in sync but if the track is sent to an external USB port to my keyboard it plays back about 210 ticks before the cursor even reach the midi note. Weird! This just started with the 2019.10 upgrade. Anyone else having this issue?
Old 11-12-2019, 09:24 AM
XJENSEN XJENSEN is offline
Default Re: MIDI notes sent to external keyboard are triggering early
Hard to tell without seeing your full setup, but I'm also having huge trouble lately with getting MIDI recording and playback in line.
Some things you might want to check already:
> Do you have LLM (Low Latency Monitoring) enabled?
> Do you have ADC (Automatic Delay Compensation) enabled?
> Make sure you didn't enter any offsets in Event>MIDI Track Offsets?
> Setup>Preferences>MIDI: Do you have delay compensation for External Devices enabled?
> Setup>Preferences>MIDI: Check the Global MIDI Playback Offset.
> Is there any kind of USB hub in between your computer and the keyboard?
> Do you have any MIDI real time properties applied (check both tracks and clips)?
Midi is played on time but midi notes are early on play back. steveooo 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 10 06-24-2020 05:07 AM
Midi Keyboard not triggering midi notes ljones macOS 0 10-17-2012 05:57 PM
Midi notes cutting out when triggering plug-ins from Pro Tools/sequencing on MPC Refresh Pro Tools TDM Systems (Mac) 7 04-11-2012 05:56 PM
Audio Triggering MIDI Notes? How? SmokinBaldMonkey Pro Tools TDM Systems (Mac) 1 02-12-2009 08:30 PM
midi triggering audio too early : ( impatientboy 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 0 10-15-2006 09:01 AM
