2019.10_ Video starts then goes black
Hello all,
Client's Pro Tools 2019.10 version either starts to play a video that immediately goes to black, or never leaves black screen. The same session works fine on my rig with High Sierra and PT 2018.7. I tried both DNxHD and Apple Pro Res 422 codecs. Video Engine is Enabled. Tried toggling between GPU on and off- makes no difference. Here are the specs: Mac OS Mojave Version 10.14 MacBook Pro (15-inch, 2018) Processor: 2.6 GHz Intel Core i7 Memory: 16 GB 2400 MHz DDR4 Graphics: Intel UHD Graphics 630 1536 MB Please let me know if there are any suggestions. Thanks
js_nyc 15" Macbook Pro (Mid 2012) 2.3 GHz Intel Core i7 16G Memory PT 10.3.11/ 12.5.2 003 Rack OSX 10.8.5 ProToolsConsultant.com |
Re: 2019.10_ Video starts then goes black
Hi
Unfortunately I must say the new video engine has still problems. It is better now and I could work with h264 codec, although if this is not as fast as it is with DNX codec I have blackmagic cards and had the same problem at the beginning. Maybe vou have tried the following. There is a setting on the video track where you can switch from progressive to interlaced and you als can switch to draft and back to full resolution. Sometimes the engine looses the setting and then I have top toggle again. On the other machine where I use desktop video there is the problem when you switch videotracks the new selected videotrack is black. I have to nudge 1 Frame and the video starts. Bad when comparing video edits between different tracks. Other problems: When doing audiosuite or loop playbacks the video goes black. I have to toggle video offline/online to get it working again It could also happen that after extensive looping this part of the video plays forever even if you play at a new timecode. Ale
2 PT HD Ultimate 2023.12 6/12-Core Westmere/ 48/96 GB / OS 10.14.6 / 96 I/O / 192 I/O / Omni / BM Intensity Pro (Driver 11.4.1) 1x PT 2023.12 Rosetta / MacMini M1 / 16 GB / monterey / SSL2+ Last edited by Ale; 11-08-2019 at 03:13 AM. |
Ale, I saw you are using BM 11.4.x with OS10.12 . Just to mention that the driver requires at least
macOS 10.15 Catalina or later or macOS 10.14 Mojave Might be worth downgrading to a driver that supports your OS. I am getting none of these issues over here with DNxHD36. Knock on wood. hm...
PTHDn 2024.3 (OSX13.6.5), 8x8x8, MacPro 14,8, AJA LHi, SYNC HD, all genlocked via AJA GEN10, 64GB RAM, Xilica Neutrino, Meyersound Acheron |
Hi frank
I know, but v 11 worked best with pt 2019.6 Before I had driver 10.4.3 installed and changed (hacked) video engine to an older version from version 12.8.2. But you are right. When I have time I switch back to a supported driver an check. All in all I am very satisfied with the new 2019.10 No crashes this week and my feeling is that everything is snappier. Ale
2 PT HD Ultimate 2023.12 6/12-Core Westmere/ 48/96 GB / OS 10.14.6 / 96 I/O / 192 I/O / Omni / BM Intensity Pro (Driver 11.4.1) 1x PT 2023.12 Rosetta / MacMini M1 / 16 GB / monterey / SSL2+ |
I have video problems also with this new 2019.10. In a session that worked perfectly with 2019.6 and also 2018.5 ; video seems to struggle then goes to black after 15 or 20mn. Very difficult to do a screening. Tried with DNXHD36, PRORES. Back to 2019.6 |
After no results with all troubleshooting, took my client back to 2019.6 and everything works perfectly again. Staying put for now.
No Video Playback (Black Video window and thumbs) | winkelement | Pro Tools 12 | 13 | 03-17-2016 11:03 AM |
And so it starts = Black Friday Sales :-) | Southsidemusic | AAX Plug-ins | 50 | 11-30-2013 06:53 AM |
PT 7.3 Video starts sluggish | peterle | Pro Tools TDM Systems (Mac) | 1 | 10-06-2008 10:43 AM |
Video Stops in Loop Playback then Starts? | joepopp | Post - Surround - Video | 0 | 04-25-2007 07:40 AM |
