Go Back   Avid Pro Audio Community > Pro Tools Software > Pro Tools 2019
Old 10-22-2019, 03:16 AM
goodBoy1 goodBoy1 is offline
Default Video playback bug with Media Composer co-install
I've just spent the whole morning trying to figure out why I couldn't get video playback to work. I managed to enable the video playback engine, and I could even see individual frames of the video when paused, However when I hit play, there was a delay, and then I would get audio playback, but the video would stay frozen.
I had recently installed Media Composer on the same machine, and then I remembered seeing something online about issues with co-installs. So, after a bit of digging, I narrowed the problem down to:
MacHD – Library – Application Support – Avid – AVX2_Plug-ins
Inside that folder is a file called OpenIO_NDI.acf. When I get rid of that, everything works normally in Pro Tools again!
It's a pretty lousy bug on the part of Avid.
Just wanted to post that in case others run into the same issue and can avoid butting your head against a wall for hours!
Old 11-01-2019, 01:21 PM
PatrickWladyka's Avatar
PatrickWladyka PatrickWladyka is offline
Smile Re: Video playback bug with Media Composer co-install
Thank you very much for posting this! We just spent a day trying to figure that one out loosing all hope already...
How did you manage to narrow it down to that?
Old 11-01-2019, 10:28 PM
Carl Sealove Carl Sealove is offline
Default Re: Video playback bug with Media Composer co-install
THANK YOU!!!!
You are a MONSTER for figuring this out!
Carl
Sealove
Old 11-25-2019, 09:15 AM
sound01 sound01 is offline
Thank you so much for working that out, my head was beginning to hurt from banging it against the wall.
Cheers
Old 01-23-2020, 01:27 PM
tlaskas tlaskas is offline
wow, thank you thank you thank you...works like a charm!
Video Satellite Media Composer. TVPostSound Post - Surround - Video 5 08-10-2013 01:17 PM
Video Satellite vs. VS-LE and Media Composer Dabbler Post - Surround - Video 7 02-10-2013 05:33 PM
Media Composer 5 and Protools Co-Install? micline 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 07-08-2010 11:41 AM
Media Composer soft v 4.02 install MIKEROPHONICS Post - Surround - Video 7 03-09-2010 07:51 AM
