Go Back   Avid Pro Audio Community > Pro Mixing > Avid S1, S3, Dock and Control
Old 10-16-2019, 02:30 PM
Cryos's Avatar
Cryos Cryos is offline
Default Ipad App 19.9.1.17
Question... Im on Sierra Mac Os Ipad is on ios 12.3.1.
I have to quit and launch the PT/Contol app at least 3 times before the Eucontrol App engages with the ipad.
What's happening is the PT/Control app shows up in Eucontrol then disappears. When it 1st shows up in the Eucontrol mac app it always shows the PT/Contol but just next to it i see the ipad name (Air2) pop up beside the name, it looks like this: PT/Control(Air2) then it disappears out of the right most connected column .. After the 3rd or 4th launch of the PT/Control app it'll show up simply as "PT/Control without the (Air2) and it engages..
Any ideas what up? other than that the app and eucontrol seem pretty stable.
Maybe I have to do a clean install of the eucontrol app? not sure what I should do.
Thanks
Cory Rizos, CAS
Re-recording Mixer/Sound Designer
Montreal, Quebec
http://www.imdb.com/name/nm0007185/
coryrizos.com
Old 10-17-2019, 10:34 AM
Cryos's Avatar
Default Re: Ipad App 19.9.1.17
Same thing is happening with Mojave btw..
Can someone at avid suggest anything?
Sent from my SM-N950W using Tapatalk
Cory Rizos, CAS
Montreal, Quebec
coryrizos.com
Old 10-17-2019, 04:58 PM
thierryd thierryd is offline
I see the same behaviour; having to start PT Control multiple times before the connection starts working.
Another thing: I can't seem to get Eucontrol to remember that it needs to lock the iPad PT Control to the DADman software for DAD AX32 control. In my memory it used to remember this with previous versions. Now I always have to re-lock it with every restart.
Greetings,
Thierry
http://www.a-sound.com/
Old 10-17-2019, 06:17 PM
Cryos's Avatar
I also tried it today with a totally different iPad running ios 13 and the same exact behavior. Would take multiple attempts to connect.
Cory Rizos, CAS
Montreal, Quebec
coryrizos.com
Old 10-18-2019, 08:07 AM
Intermittently seeing the same behavior here. PTU 2019.6, EuControl 19.9.1.17, PT Control 19.9.1.17, but just realized my iPad is still on 11.4.1. PT Control shows up in surfaces list and seems to connect, then switches to *available* while still greyed out and disappears from both columns. iPad app seems frozen and never shows connected in green at the top.
UPDATE: Seems like having the iPad app and the artist mix already powered on, then restarting seems to work, but I';ll have to test a few more times to confirm.
Scott Gatteño
Yessian
Old 10-18-2019, 03:38 PM
Cryos's Avatar
Tried all that too. Nothing seems to work. Avid got back to me and didn't have any real viable solution other than reinstall all the eucon software..toss prefs and reinstall App. None of it worked .. has to be a bug .. what's the likelyhood of this happening with different iPads on 2 totally different machines !
Cory Rizos, CAS
Montreal, Quebec
coryrizos.com
iPad Pro 9.7" VS. iPad Air 2 ? reichman Avid S1, S3, Dock and Control 1 08-07-2016 11:46 PM
Anyone have pics of iPad mini and iPad Air side by side! Brandonx1 Avid S1, S3, Dock and Control 4 06-07-2016 08:03 AM
come on - where is the ipad app??? muesli VENUE Live Sound Systems 19 12-21-2015 02:45 PM
pd and iPad automatized Avid Scorch (iOS) Forum 0 03-14-2012 11:03 AM
Ipad App brickroadstudio Pro Tools 10 31 02-23-2012 01:01 PM
