Go Back   Avid Pro Audio Community > Pro Tools Software > Pro Tools 2019
Old 08-25-2019, 04:13 AM
danyg danyg is offline
Default CPU question mono vs stereo
I made some tests without clear/satisfying results and I was asking myself:
if
- a MONO channel with with mono plugins has less CPU usage than a stereo channel (we get a lot of stereo bounces these days from mono tracks) ?
- there is a difference between PT plugins behaviour and 3rd party plugins - I tried 40 Waves Plugins in mono and stereo and got no real difference in CPU
- is it worth to split the stereo tracks that don't need to be mono (or just a loss of time)
What is your experience? Thanks
PS: OSX PT 2019 - I'm not talking about multi mono.
Mac Pro 12 core 3.46Ghz - 64 Gb ram - SSD 500 Gb - HD1 2T - HD2 2T - OS 10.10. - Mac Book Pro retina- OS 10.10. - SSL Alphalink convertor - Pro Tools 12 native - SSL Matrix console - Logic Pro X
Old 08-27-2019, 04:08 PM
Default Re: CPU question mono vs stereo
no-one with more information?
Old 08-27-2019, 04:14 PM
off the wall's Avatar
off the wall off the wall is offline
if
I always split real mono tracks if delivered as stereo. It just makes panning, bussing etc easier. It also takes 1/2 the voices. I gotta believe that most plugins use less CPU in mono but have no real proof that is so.
offthewallproductions
Mac Pro 5,1 3.46 Ghz 12 core, AMD 7970 GPU, SSD boot drive on 6Gb/sec PCIe card, 64GB RAM, MacOS 10.14.6.
Pro Tools Ultimate 2019.12. HDX, UA Octo PCIe cards, HD I/O, C|24 control surface.
Mostly Avid, Waves, Sonnex and UAD Plug-ins
Genelec 1031AP/7070A 5.1 monitoring.
Old 08-27-2019, 04:51 PM
BScout BScout is offline
https://www.soundizers.com/
panning stereo tracks that are actually mono is an annoyance which is the first reason to get rid of them.
Pro Tools Ult 2019.12, HDX 3, MTRX/SPQ, HD OmniMac Pro 5,1 - 3.06 GHz 12 core - macOS 10.13.6RAM 64GB, SSD 4 x 2TB, GPU GTX 980 4GB
Old 08-27-2019, 08:46 PM
cwsand's Avatar
cwsand cwsand is offline
Yes, and they just make the session larger.
Help Us Help You
Chris
__________________________________________________
Focusrite Liquid Saffire 56
TCE Studio Konnekt 48
PreSonus Digimax LT
Gigabyte GA-Z170-HD3P / i7 6700K 4.1 GHz / 32GB Crucial DDR4
macOS High Sierra Version 10.13.6
Pro Tools HD 2019.12
Old 08-28-2019, 01:38 AM
- BScout,
I have Soundizer but I find the algorythm a bit too "strict". If there is a tiny bit of noise on one side of a stereo kick or snare it doesn't convert it to mono. Wish it was a bit more loose (if that makes sense).
- off the wall,
So Vanilla can play 256 mono tracks ?
The CPU window is so sluggish. You can almost read nothing concrete
Old 08-28-2019, 07:30 AM
- off the wall,
No, Vanilla can play 128 VOICES at 48k. That would be 128 mono tracks or 64 stereo tracks.
Old 08-28-2019, 10:05 AM
JFreak's Avatar
JFreak JFreak is offline
That is incorrect -- Vanilla can play 128 audio tracks, mono or stereo, and don't care about voices at all. AFAIK that is, correct me if things have changed lately with the new voice packs that I don't have and think are Ultimate-only anyway.
Voice is a DSP concept that means i/o point of mixer.
EDIT: this thought haunts me now, please someone test if creating 128 stereo tracks is possible with vanilla (cannot test myself with this license bundle)
Janne
Old 08-28-2019, 10:10 AM
I was just going by what AVID had to say about it here:
https://www.avid.com/pro-tools/comparison
What is a voice?
"A voice is a single audio stream that roughly equates to one mono audio track. A mono audio track will use one available voice. A stereo track will use two available voices. The voice limit is Pro Tools' capacity to play back a multitude of simultaneous voices. The higher the voice limit, the more tracks you can play back in Pro Tools to work on bigger, more demanding sessions."
Old 08-28-2019, 10:12 AM
JFreak's Avatar
Yes, that is a voice. But standard software is not about voices, that ad material is talking about tracks (mono or stereo bcs greater-than-stereo are not available). Voices are only used/calculated in HD/Ultimate. Maybe if all users could do their math it would have been simpler for Avid to allow 256 voices for standard software but as most are only counting tracks limiting to 128 seems sensible.
Janne
Stereo to mono question stixman Tips & Tricks 1 09-01-2016 02:45 PM
A question about mono/stereo plug ins on mono tracks. rockguitarist1255 Pro Tools 10 2 12-24-2011 08:33 PM
mono/stereo question studiokeyz 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 5 01-13-2008 02:25 PM
Stereo / Mono question Daubian Tips & Tricks 2 03-16-2007 05:26 PM
Stereo or mono, that's the question. rgr VENUE Live Sound Systems 5 03-06-2006 03:32 PM
