How to Join & Post  ē  Community Terms of Use  ē  Help Us Help You
Knowledge Base Search  ē  Community Search  ē  Learn & Support
Go Back   Avid Pro Audio Community > General Discussion & Off Topic > General Discussion
Old 08-05-2019, 02:41 PM
Raoul23 Raoul23 is offline
Default Patch bay problems
Ok guys I got hold of a warm audio 1176 and want to patch it in so I can use it on anything from vocals to bass. Iíve tried to do it but with no success yet, hoping someone here can help.
The equipment Iím using
Behringer patchbay PX 2000
Warm audio 1176
Tech 21 RBI
I record bass on analog input 5 in all my ProTools sessions
Iíve connected the RBI and Compressor together to make sure it all works and it does. Now when Iím Iíve hooked it up to the patchbay it doesnít work??
Instead of me trying to explain my signal flow Iíve drawn a picture. Patchbay slot 1 is set to normal and patchbay slot 2 is set to open
Raoul Crane
www.blaze-studios.co.uk
PT 10.3.10 HD Accel 6, Mac Pro 3.1 Dual Boot Lion 10.7.5 and Maverick 10.9.5 32GB Ram Magma PE6R4i Chassis
Old 08-05-2019, 03:15 PM
64GTOBOY's Avatar
64GTOBOY 64GTOBOY is offline
Default Re: Patch bay problems
Well your diagram shows the input and output of the 1176 on one patch which wont work unless you are non normalled. I would run the comp out on the same patch as PT in and comp in by itself or you can have it normalled to one input device and just patch to others from the front.
Dell XPS 8900 i7-6700K CPU @ 4.00GHz 32 Gig Memory:Seagate 2 TB,1TB,4TB,500gb EVO OS Windows 7 Ultimate
PT 2019.6 Native through A&H Qu-32
Old 08-05-2019, 03:28 PM
The 1176 is set to open, here is how Iím patching it on the front
Raoul Crane
Old 08-05-2019, 07:28 PM
Bob Olhsson's Avatar
Bob Olhsson Bob Olhsson is offline
It appears that you want to use that 1176 in a Pro Tools insert. Is that correct?
I would advise recording the bass without the SansAmp or 1176 with the player listening to a studio monitor. That way the player controls the dynamics and tone with their fingers and "touch."
Bob's room 615 562-4346
Interview
Artists are the gatekeepers of truth! - Paul Robeson
Old 08-06-2019, 02:07 AM
Hi Bob
I want to be able to patch the 1176 in to anything later on down the line when I purchase some more preamps. Iím just using the sansamp really to head my head around setting up the patch bay
Raoul Crane
AMS Rescan and Patch Name Problems artk2002 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 02-07-2012 08:29 PM
Patch Names and Playback Problems! faba MIDI 0 05-02-2010 04:04 AM
Patch select problems sevenson 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 04-03-2009 08:04 AM
midi patch files problems help please??? doopman Pro Tools M-Powered (Mac) 2 09-18-2007 12:03 AM
Patch Name Support problems MDog Pro Tools TDM Systems (Win) 7 02-17-2005 07:26 PM
