Go Back   Avid Pro Audio Community > Pro Mixing > Avid S1, S3, Dock and Control
Old 08-03-2019, 02:31 PM
Mr Base Mr Base is offline
Default DADMAN and Protools on 2 Separate Computers EUCON PT|CONTROL
Dadman and PT on same computer when PT is in focus, monitor tab of PT | CONTROL is blank. Until DADMAN is in focus it remains blank.
Is there any way to run DADMAN on a 2nd computer so its always in focus or another configuration for 1 computer so u do not have to focus DADMAN every time you want to use the Monitor Controls ? Will PT Control worth with 2 Eucon Sources 1 being DADman on 1 Mac and PT on the other Mac ?
Can this be done with 1 or 2 MACs ?
Thanks
Old 08-03-2019, 05:48 PM
LukeHoward LukeHoward is offline
Default Re: DADMAN and Protools on 2 Separate Computers EUCON PT|CONTROL
Thanks
You can lock monitor control to DADman in the EuControl app. It’s in one of the tabs (I forget which).
Old 08-04-2019, 12:06 AM
BScout BScout is offline
Assign Tab.
That's how it should be done.
Pro Tools Ult 2019.12, HDX 3, MTRX/SPQ, HD OmniMac Pro 5,1 - 3.06 GHz 12 core - macOS 10.13.6RAM 64GB, SSD 4 x 2TB, GPU GTX 980 4GB
Need Pro Tools on two separate computers to be able to access two Apogee Symphonies MSCStudent Pro Tools HDX & HD Native Systems (Mac) 9 07-28-2018 04:24 PM
procontrol to control both HD3 version8 and 003 version10 on separate computers iain.sbprod ProControl, Control|24, Command|8 1 10-08-2015 01:28 AM
LOCKING LOGIC TO PROTOOLS- BOTH ON SEPARATE COMPUTERS gw sound Pro Tools TDM Systems (Mac) 10 06-29-2007 10:39 AM
Reason and PT LE on separate computers... AdamF 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 4 05-30-2003 01:56 AM
Using Separate Computers for Soft Instruments/Synths Mr_Seven 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 8 07-01-2002 09:29 AM
