Old 07-25-2019, 09:18 AM
zavid zavid is offline
Default Best Word Clock Generator ….."Rock Around The Clock©"
Apogee ? Rosendhal ? Avid ? Antelope Audio ?
Black Lion ?
what best for Pro Tools ?
Old 07-25-2019, 09:51 AM
JFreak's Avatar
JFreak JFreak is offline
Default Re: Best Word Clock Generator ….."Rock Around The Clock©"
Depends on your needs. If you only have Avid interfaces, you don't even need any. What do you need to sync toghether? Just WC devices or video as well?
Janne
Old 07-27-2019, 02:00 AM
audio only
Old 07-27-2019, 04:15 AM
JFreak's Avatar
Again, how many devices outside Avid interfaces that are loop synced together?
Janne
Old 07-27-2019, 09:45 AM
dr sound's Avatar
dr sound dr sound is offline
These are great!
https://www.markertek.com/product/br...versal-outputs
Very flexible.
Marti D. Humphrey CAS
aka dr.sound
www.thedubstage.com
IMDB http://www.imdb.com/name/nm0401937/
Like everything in life, there are no guarantees just opportunities.
Old 07-30-2019, 07:28 AM
Default
actually only 1
but i planned to have 3-4 in the future
by different manufacturers
i read many posts and also it's so famous that there is jitter and aliasing issues
without a serious master clock generator,..unfortunately...
Old 07-30-2019, 09:48 AM
arche3's Avatar
arche3 arche3 is online now
I think for a single device let it clock itself. If multiple different vendors etc I can see the value of a master clock. If just avid I don't see the need. I read an article from one of those digital audio clocking guru guys about it in the past.
The conclusion from this article was its placebo in most cases.
Sent from my SM-G975U using Tapatalk
Old 07-31-2019, 02:01 AM
Farhoof's Avatar
Farhoof Farhoof is offline
Jitter is only an issue at the DA converter stage. Before that there can be frame/clock mismatches that results in clicks and pops. The need of a wordclock really depends on your setup. If you got some external devices able to clock to the incoming spdif/aes signal then you're all good to go.
At some point when your setup/studio is large enough it's far easier to just sync the whole place to a single wordclock.
Old 07-31-2019, 02:48 AM
JFreak's Avatar
Originally Posted by zavid View Post
actually only 1
So for now at least you don't need a master clock. Every Avid interface has a wordclock i/o in addition to loop sync i/o which means you can use that for clocking.
Also, if your total cable length is not out of this world, simple passive t-splits and proper termination at the end should do the trick. In your shoes I would try that first before even thinking about a master clock.
Janne
"Problem detected with audio clock. Check audio clock and sample rate." Focusrite 2i4 Terry Wetzel Third Party Interfaces 10 11-08-2013 06:18 AM
FS UK: LA Audio Word Clock / Super Clock Generator DigitalMetal Buy & Sell 0 12-05-2012 03:22 PM
Word Clock Issues "the HW device is at a different sample rate from the open session" daveseviltwin 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 3 12-11-2011 06:09 PM
Audio clock problems.."Check clock source and sample rate.." Please help! beasleymusic Pro Tools M-Powered (Win) 1 08-03-2011 10:54 PM
Word Clock Generator jeffwuollet Tips & Tricks 28 05-21-2005 03:36 PM
