Go Back   Avid Pro Audio Community > Pro Tools Software > Pro Tools 2019
Old 06-22-2019, 09:49 PM
SBP SBP is offline
Default Bug: Sub paths messed up
Hi -I have noticed an issue with the creation of subpaths on ProTools Ultimate 2019.5 and can repeat the issue every time on my system here. perhaps someone else could check this out and see if the issue is just my system.
Create an audio track.
click on the clear space to add an AUX Send on the track and select "new track"
Make the width "5.1" and the type "Aux"
Click on create
now go to the I/O setup
click to reveal the sub paths of the new aux
I see the sub paths with the ch assignments all messed up. (Right of 5.0 is assigned to Centre or 5.1.... among other things)
When I create a new path via the I/O setup page and tick (auto create sub paths) everything looks as I'd expect.
Cheers
Bruno
Old 06-23-2019, 04:52 AM
Default Re: Bug: Sub paths messed up
What happens if you click on a send slot in the track you want to create the send in and select 'new track' and do the rest of your business?
Jack
QAPLA!
Old 06-23-2019, 02:23 PM
SBP SBP is offline
Bruno
Old 06-23-2019, 02:41 PM
Originally Posted by SBP View Post
Gidday Jack.... its a mess; thats what I'm seeingAttachment 11857
Bruno
Understood but you didn't answer my question: what happens if you create a new track from a send in the usual way of right clicking a send slot?
Jack
QAPLA!
Old 06-23-2019, 03:10 PM
SBP SBP is offline
On my system you don't get the option of right clicking the blank space in the Aux slot- its just a normal click in the blank space that will bring up the drop down menu. Then you select 'new track'... As I described in my first post. and the pic shows the result. The main path is fine however the sub paths are a mess.
Anyway I'd be interested in hearing if others see the same result. (or not)
I don't think there is any user preference that would contribute to this result.
All the best
Bruno
Old 06-24-2019, 04:12 AM
All the best
Bruno
Forgive me as I made an error - it's a regular left click for those who's mice are setup normal. On my system I work lefthanded and the mouse buttons are swapped left for right.
Jack
QAPLA!
Old 06-25-2019, 10:28 PM
SBP SBP is offline
I've noticed the sub paths are also created all messed up, when made via "new track" method in Protools Ultimate 2018.12.0 so this is probably a long standing bug.
Bruno
Old 06-26-2019, 08:54 PM
MacBook Pro 2016 Touchbar
OS 10.12.6
PT|Ultimate 2019.6
Aux 1 created via Send drop-down menu-> New Track
Mostly ok except for Quad. Default path order for 5.1 set to Film in Output page drop down menu. No change when default path order is set to SMPTE. Sub-paths are all correct when creating new path+sub-paths in I/O Setup window.
Same issue with 7.1. Quad incorrect when using Send->New Track method, all sub-paths correct when creating inside of I/O Setup window.
File Type: jpg Screen Shot 2019-06-26 at 10.42.26 PM.jpg (51.3 KB, 0 views)
Scott Gatteño
Yessian
Old 06-27-2019, 04:52 AM
I wonder if there would be any difference if one used the keyboard shortcut on Macs of cmd-shift-n to bring up the new track dialog? Also wonder if any Windows users are seeing the same thing?
Jack
QAPLA!
Old 06-27-2019, 07:47 AM
I don't think the new track dialog creates a bus in the same way that creating a send using the "new track" option also creates a corresponding bus. This is specifically about the system creating a bus and mis-assigning the sub-paths.
Scott Gatteño
Yessian
"Some paths dropped, only mono and stereo paths supported" LSNY Pro Tools 12 3 08-22-2017 06:40 PM
Stereo HD Native Low Latency monitor paths are a no go with active surround paths? vieris Pro Tools 12 3 07-27-2015 07:07 PM
Question about Sub Paths and Main paths. oulablank 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 08-15-2009 01:15 PM
Understanding Paths Mike62858 Pro Tools M-Powered (Win) 0 04-20-2007 07:25 PM
PFL/AFL paths Robin Reumers Pro Tools TDM Systems (Mac) 1 09-04-2006 12:39 PM
