Old 06-08-2019, 03:51 PM
dez811 dez811 is offline
Default Pan
Pan Not working on the mixer view on iPad app, also when moving pan knob in pro tools it does not show up on iPad app.
Latest pro tools, eucon, and iPad app
Old 06-08-2019, 10:45 PM
jeffro's Avatar
jeffro jeffro is offline
Default Re: Pan
Same here... will start a case for you and log this.
system detailsxinstagramlinkedin
Old 06-17-2019, 09:13 AM
Default Re: Pan
doesn't work in logic either!! very sad, who tests these things? seems like the whole DUC is about fixing broken things nothing works right the first time and when it does you break it. the key seems to be when it does work leave it alone I've seen this many times in the forum but my smart A@@ had to upgrade. I'm the idiot not Avid they are the geniuses they keep charging for minor upgrades sometimes it works sometimes it doesn't. well I got off easy my investment is small and I make plenty lucky me
Old 06-18-2019, 01:22 PM
EddieJones's Avatar
Default Re: Pan
We have never charged for EuControl or the Control App, users who bought over 11 years ago are still getting free features and upgrades.
This issue posted is a one off with an old session. If you have a similar one with Logic its probably something completely different and quite possibly on Apple who write the Logic EUCON adapter. Please check for Logic posts (there are a few) and if not start a new thread and we can work through it and either fix it on our side or send to Apple.
Old 11-07-2019, 02:04 PM
jeffro's Avatar
Default Re: Pan
I updated the Pro Tools Control app (and EuControl) to v19.9.1.17 and Pans are working correctly now. Can you please try this when you have a chance and report back?
Old 11-25-2019, 07:23 PM
Default Re: Pan
still not working
Old 11-26-2019, 10:13 AM
jeffro's Avatar
Default Re: Pan
still not working
What versions of Pro Tools Control and EuControl (and Pro Tools) do you have installed?
Old 11-27-2019, 06:43 PM
Default Re: Pan
Eucontrol 19.9.1.17
iOS 19.9.1
Old 11-27-2019, 08:08 PM
Default Re: Pan
Played with it today the pan worked for a sec then opened a different session and it stopped. Also when i hit the channel tab it is now blank nothing, nada is there this is annoying but like Eddie said in a previous post its free so I suppose I shouldn’t expect much even though i own a dock. Also i could be wrong but i thought when i went to the last tab where i can select which type of tracks i wanted to view like vca’s or aux’s etc. it was reflected in pro tools if it did work it doesn’t now. I think i liked it when euphonics ran the show
Old 11-28-2019, 07:25 AM
Default Re: Pan
I got the pan to work by going in the preferences and unchecking boxes and restarting Eucon but after opening a new session it went back to not working. I don’t know which boxes I unchecked because there are too many and the same combinations didn’t always work and I Don’t want to be a beta tester.
On the channel disappearing the same thing worked, uncheck boxes restart eucon and it returns sometimes. I’m done this is no different than pro tools some things work other’s don’t I don’t dare vent too much before someone with thousands of posts gets on this thread and starts berating me and telling me about how theirs works and I’m doing something wrong or maybe I should go to another daw.
These people usually have thousands of posts which in my eyes means they cant be getting much work done I make a living doing this and have been using protools since the audio media III card.and I do not have time to post or be a beta tester. in the many years I have been on this forum my posts are minimum. Get it together avid! The only reason I use this platform is because it’s convenient when I get a pt session to stay in protools especially with a bunch of automation, edits, etc. Any especially when you have many sessions to get out
But when I get stems I use other daws and my mixes are fine
