Can't delete some files/clips
Selecting "Unused" clips in the clip pane results in a number of files being selected which, when I attempt to delete them, result in an alerts which says "<<File.aif>> can not be deleted from disk! Clips from it remain in this session. Do you want to remove it from this session?" However the file in question has no clips visible in the clip pane, and the file itself is not used. Before I did this op, I did "select unused except for whole files" and deleted the resulting clip list, so no unused clips should remain in the session. This is new behavior for PR 2019.5 - I've been using PT for a while and didn't see this in any of the 2018 versions. MacOS 10.12.4. Attached screen shot shows the alert and the portion of the clip list showing the file in question.
Does anyone know a workaround? I'd like to (safely) delete a bunch of unused cruft from my sessions without having to respond "Yes" to that rather dire warning dozens of times. Thanks. |
Re: Can't delete some files/clips
check that your showing "auto created" in the clip bin.
http://www.richbreen.com ---------------------------------------- Mac Studio / Ventura, PT 2023.12.HDX, Avid HD I/Os and Metric Halo ULN8, 3xS1/Dock Also running a Mac Studio Ultra / Ventura / HDX / MTRX / S6 |
That was it. I never even knew about this option, so I'm pretty sure I never changed it. It's possible that updating to 2019.5 changed the default for this to "off"...but in any case I'm in business. Thanks!
Delete unused clips from project | LivingThings | Pro Tools | Intro Discussion | 2 | 11-08-2017 08:53 PM |
Delete Clips Under Certain Length | Loyal Apple Geek | Pro Tools 12 | 5 | 03-22-2017 03:42 AM |
How to delete empty audio clips and files automatically in PT? | Rockman413 | Pro Tools 12 | 4 | 03-22-2016 10:46 PM |
Delete muted clips | lode | Pro Tools 11 | 0 | 04-10-2014 01:00 AM |
Drag Clips = Delete Clips??? | Connor | macOS | 2 | 07-09-2012 07:50 PM |
