Old 05-14-2019, 11:03 PM
himunebato himunebato is offline
Default Sequential bouncing/region export
hey everyone, i’ve used Reaper for many years and now i’ve started transitioning into Pro Tools. up to now it’s been fine but there’s something i miss and haven’t figured out how to do, if it’s possible. in Reaper, you can set markers, like the memory locations in PT, and between these markers create a region, then name the region and when exporting you can batch export all of them in sequence according to that region number, and also include the region name in the filename. now, i figure region means something else in PT, but is there a way to do this?
Old 05-15-2019, 07:47 AM
Default Re: Sequential bouncing/region export
In Pro Tools(starting at version 10) an audio file is called a "clip". Read the manual about "Export Clips as Files". I think that may cover your needs.
Old 05-15-2019, 12:00 PM
BScout BScout is offline
Export clips as files will not printdown plugins on the channel or automation. I’d printdown (through bussing) to another audio track, copy region edits down to break up the large file, name regions (you can use batch rename here) and then export clips as files
Pro Tools Ult 2019.6, HDX 3, MTRX/SPQ, HD OmniMac Pro 5,1 - 3.06 GHz 12 core - macOS 10.13.6RAM 64GB, SSD 4 x 2TB, GPU GTX 980 4GB
Old 05-16-2019, 03:54 PM
thanks for the tips! using the batch rename function doesn't make it as automated as it was in reaper, but this and the export clips as files function after printing already saved me quite some time
-Mac Pro 5,1
-22GB RAM
-macOS High Sierra
-2x Xeon 2,4GHz CPU
-Tascam US 16x08
-Pro Tools 2018
Export region as files sode macOS 8 04-01-2011 02:35 AM
export region as file BUG? lukeyy Pro Tools TDM Systems (Mac) 0 12-04-2010 10:46 AM
[Trying To] Export Region Definitions Sound Guy Andy Post - Surround - Video 1 07-24-2009 06:07 PM
New bug: Can not export region files Alécio Costa Pro Tools TDM Systems (Mac) 2 02-23-2008 06:02 AM
MIDI Region Export nikki-k Tips & Tricks 4 07-26-2006 11:14 PM
