Old 05-09-2019, 08:59 AM
mixer mixer is offline
Default 2019 ultimate and heat
Heat is no longer showing up in 2019 ultimate It no longer seems to be supported.. bummer
www.garyvandy.com
Old 05-09-2019, 09:07 AM
Sayt0n Sayt0n is offline
Default Re: 2019 ultimate and heat
I will have to check this when I install this update later on tonight. This would be another dumb move on their part though if this is the case. What about people who spent money to buy a license a couple months ago at the full list price!? They basically rendered that license useless and another waste of an investment in AVID.
Can anyone else confirm this!?! Could it be it just did a bad install?!
Old 05-09-2019, 09:10 AM
jeffro's Avatar
jeffro jeffro is offline
Working here. Can you verify that the HEAT license is on the same iLok as your Pro Tools Ultimate bundle? If it's there, try deactivating then activating it again.
File Type: jpg Screen Shot 2019-05-09 at 9.20.36 AM.jpg (36.3 KB, 0 views)
• linkedin •
Old 05-09-2019, 09:17 AM
Meads Meads is offline
Can confirm.
iMac Pro
- MacOS 10.14.6
- Pro Tools U HDN 2019.6
- Avid HD Omni + HD I/O 8x8x8
- C|24 | S3 | Dock
Old 05-09-2019, 09:43 AM
BScout BScout is offline
HEAT is working here. Same as always with 2019.5
Pro Tools Ult 2024.3.1, HDX 2, MTRX/SPQ, RME BBF Pro + MADIface Pro • S1 x 2, Fire Max11 x 2, Dock, iPad Air5 • Mac Mini 14,12, 12 core, macOS 13.6.6 • RAM 32GB, SSD 4TB, GPU 19 core • QNAP TVS-872XT 148TB TB3
Old 05-09-2019, 10:47 AM
Southsidemusic's Avatar
Same
Best Regards
Christopher
#thestruggleisreal
South Side Music Group
WEBHOME
Old 05-09-2019, 11:03 AM
ericsvizeny ericsvizeny is offline
Just tried this.. Still no heat showing up.
Old 05-09-2019, 12:11 PM
TrentWilliams TrentWilliams is offline
Same
Pro Tools 2024.3.0|Perpetual • MTRX Studio • HDX1 • Sync-X • S3 • Dock • Mac Mini 2018 - 3.2GHz i7 6-core macOS 13.6 • RAM 64GB DDR4 GPU AMD 6900XT 16GB • Monitor LG 32UL950-W
Old 05-09-2019, 02:51 PM
Kyle Splittgerber's Avatar
Kyle Splittgerber Kyle Splittgerber is offline
For those of you seeing the issue...
Will you download latest iLok License Manager, relaunch Pro Tools, and check?
https://www.ilok.com/
Kyle Splittgerber
Senior Principal Product Designer
Berkeley, CA
Old 05-09-2019, 03:11 PM
Just tried this. No luck.
If it helps any I did the update through "Avid Link". As opposed to downloading from the Avid website. Maybe wouldn't hurt trying to re-install?
Also, getting this message when opening a session with heat on it:
File Type: jpg Screen Shot 2019-05-09 at 6.10.26 PM.jpg (30.5 KB, 0 views)
Avid Heat + Non Ultimate Pro Tools MikeP89 Pro Tools 2018 32 05-09-2019 06:43 PM
Ultimate 2018 Update renewal - Heat & Complete Plugin Bundle? WKG Licensing & Accounts 23 12-29-2018 11:29 AM
Ultimate where's HEAT authorization? TVPostSound Pro Tools 2018 38 04-16-2018 09:26 PM
Does comping to a Heat enabled track print the Heat? joshdrucker macOS 0 03-12-2014 10:17 PM
