Old 05-04-2019, 03:45 PM
field3d field3d is offline
Default “GUIRO” Preset Xpand! Protools 2018
I’m using the latest version of Pro Tools 2018. I want to know if it is possible to have “GUIRO”, or already exists in Xpand2!? Yes, where? I see in percussions menus congas, others but not “GUIRO”. Any idea? Or is not possible?
Old 05-04-2019, 04:03 PM
bobcharest bobcharest is offline
Default Re: “GUIRO” Preset Xpand! Protools 2018
For those kinds of instruments, I installed the Latin Percussion EZX from ToonTrack. It has 3 Guiros.
You need to have EZ Drummer 1.4 or above or Superior Drummer 2.3 or above.
Best regards,
Bob Charest
Best Regards,
Bob Charest
__________________________________________
Macbook Pro, Mac Mini, High Sierra 10.13.6, Protools 2018.12.0
Old 05-04-2019, 04:17 PM
amagras amagras is offline
There are guiros in 27 Percussion/Natural Percussion and Grammophone Percussion. Try C#4 and D4.
Dell XPS 8700. Intel Core i7-4770 CPU @ 3.40GHz. RAM: 16GB. Windows 10 Home x64. NVIDIA GeForce GTX 645. NI Komplete Audio 6. Pro Tools Software 2019
amagrasmusic.com
Old 05-04-2019, 05:02 PM
Thank you for answer. I attach a picture of how I make in Sibelius the notation:
https://ibb.co/LtTJxZd
In Sibelius I export as midi always my things and I use drums rock kit, bass, etc. In this case if I export as midi my notation of guiro exactly as the picture, then I just attach apply in Xoand2! natural percussion or grammophone, and that’s all? Or what you meant with C#4 and D4, where you modify that?
Old 05-04-2019, 05:04 PM
Just use C# and D one octave above the central C with the first preset I mentioned. This guiro has only 2 articulations
amagrasmusic.com
Old 05-05-2019, 11:08 AM
I used as you say and there is a sound indeed, like a guiro, however when I out my notation above and I put the notes in Pro Tools when is heard the kind of guiro, yes appear in C# or D but the final result sounds as constant snake almost not found up or down and not sounds as for example this video after second 15:
https://youtu.be/KxxDWc08nSo
What would happen?
Old 05-05-2019, 11:42 AM
Raise the velocity of the MIDI
amagrasmusic.com
Old 05-05-2019, 06:15 PM
It worked I had another effect interfering. It works now. I see sounds good, not the best quality but it works now to solve the problem. Maybe in future I will check what says “bobcharest” of EZdrummer or maybe Superior Drummer 3 for best quality, but it is working now to get out of the problem.
Thank you so much
Old 05-05-2019, 11:04 PM
seanmccoy seanmccoy is offline
If you've got Kontakt and want to get fairly serious about guiro programming, check this out:
https://www.loopsdelacreme.com/kontakt-libraries
Unfortunately/fortunately I'm married to a really fine percussionist, so I'm not allowed to use it.
ADK Core i7 4.20, 32GB RAM, W10 Pro, PT HD 2019.5, HD Native, OMNI, Digi 192, AJA Kona LHi, UAD-2 Quad; Mac Pro 8-core 2.67, 32GB RAM, High Sierra 10.13, Logic Pro 10.4.6, Apogee Rosetta 800, MOTU 2408 Mk II: MBP mid-2012, 16GB RAM, Sierra, MOTU LP32, Pro Tools 2018.3
Old 05-09-2019, 01:22 PM
So nice :)
2018.7 Track Preset question HomePlayer Pro Tools 2018 8 08-01-2018 11:31 PM
Track preset key command PT 2018 tomdiek Tips & Tricks 1 03-03-2018 11:52 AM
Xpand!2 2018 & Air Instruments 2018 lgreen100 Pro Tools 2018 16 02-15-2018 05:01 PM
I lost my preset (Vacuum and Xpand) When i upgrade to 8.0.3 (Mac Pro) Snow Leopard DJ Romy 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 07-10-2010 10:46 AM
xpand preset songman Virtual Instruments 7 12-22-2009 10:40 AM
