Old 02-09-2019, 11:41 PM
Blake Henderson Blake Henderson is offline
Default Apogee Symphony (MK1 and MK2) in Pro Tools HD mode. Low latency Monitoring?
Hi all.
I currently own and use the Apogee Symphony IO MK1 and am considering upgrading to the MK2.
My question relates to the device in "Pro Tools HD" mode. I use a hybrid setup with several Hardware inserts. Pro Tools native does not automatically compensate for the latency incurred when using hardware inserts (unless you have their hardware) so I am planning to use My Symphony in "Pro Tools HD" mode via an HD native thunderbolt device.
The question is this: When using the MK2 in Pro Tools mode am I still able to use apogee's "control" software to monitor with near zero latency? When switching my Symphony MK1 to Pro Tools HD mode, the Maestro mixer section disappears.
I'm hoping that I can use the MK2 in Pro Tools HD mode while also making use of the Apogee Control Mixer to monitor as I track.
Anyone out there using the Symphony with Pro Tools? any tips or advise? I've heard that the MK2's latency via thunderbolt is quite good but without Pro Tools HD mode I'm still dealing with Hardware insert latency.
Blake Henderson
Clumsy Congregation
Old 02-10-2019, 05:40 AM
JFreak's Avatar
JFreak JFreak is offline
Default Re: Apogee Symphony (MK1 and MK2) in Pro Tools HD mode. Low latency Monitoring?
I have the mk2 and can test this for you shortly. Usually I just use it in TB mode but I do have the HD option card installed just in case I need to take this box on the road
Janne
Old 02-10-2019, 07:03 AM
JFreak's Avatar
Yea it is possible, but without the control software you need to set it up through the touch-screen menu
Janne
Old 02-10-2019, 08:28 AM
Thanks Jfreak.
Are you saying you have access to full “mixer” options? For instance, what if I wanted to send inputs 1-5 to the headphones and inputs 6 and 7 at half volume? Does the touch screen give you that much control?
Clumsy Congregation
Old 02-10-2019, 08:36 AM
JFreak's Avatar
Sorry, I didn't take it that far but I cannot see why not as the LLM mixer is already there. Have you read the manual? I must confess I haven't
Janne
Old 02-10-2019, 08:43 AM
I did read the manual actually. It only shows a monitoring screen where you can choose what is routed to the outputs and phones but it seems to be very minimal, maybe only allowing you to choose one channel per monitoring output. The manual really didn’t get detailed. Do you see a menu that shows a mixer view similar to the control software?
Thanks lot! The answer to these question stands between me and the MK2
Clumsy Congregation
Apogee Symphony 64 w/ Pro Tools Native HD clancychris Pro Tools HDX & HD Native Systems (Mac) 6 10-26-2017 01:12 PM
Pro Tools HD2 AND Apogee Symphony Sonic Arts Center Pro Tools TDM Systems (Mac) 2 04-22-2013 06:49 PM
Apogee Symphony, symphony 64, motu 128, 3u rack case chrisgil Buy & Sell 1 02-18-2013 10:48 AM
Apogee Symphony and Pro Tools 9 via USB? Brown Teeth macOS 4 03-02-2011 12:50 PM
Apogee Symphony 64 and Pro Tools 9 forjam Pro Tools 9 3 11-07-2010 06:11 PM
