Go Back   Avid Pro Audio Community > General Discussion & Off Topic > General Discussion
Old 01-23-2019, 05:33 PM
cwsand's Avatar
cwsand cwsand is offline
Default Re: True or False or
Neither is true - they aren't "problems", just something to be aware of.
Help Us Help You
Chris
Pro Tools 2024.3
Focusrite LS56
Focusrite Pro40 (2)
TC Electronic Studio Konnekt 48
Avid Artist Mix/Control
Slate Digital VRS8
Analogue Tonebuss 24 Channel
UAD-2 OCTO Core Accelerator
UAD Volt 2
macOS 10.15.7
32 GB DDR4 RAM
NVIDIA GeForce GT 740 2 GB
Old 01-23-2019, 05:50 PM
Top Jimmy's Avatar
Originally Posted by amagras View Post
Then I'm right!
I understand the importance of proper gain staging but once you have everything inside Pro Tools you only have to worry not to saturate the analog algorithms of analog emulation plugins and the master/converters. That can easily be done with clip gain and the channel faders....unless you mean that once ITB gain staging doesn't exist at all
The simplest aspect of gain staging that everyone learns is to achieve a good signal to noise ratio without clipping. Stick to the job of recording long enough and hopefully you'll learn two other aspects of proper gain staging.
1) Don't drive the analog side too hot even without clipping unless that is what you want. The last 6dB in a circuit is the nastiest as far as sound quality.
2) Gain staging also needs to account for relative levels between tracks. Mixing begins at the gain knob. Learn this and you'll achieve great results quicker and easier.
James Cadwallader
Old 01-23-2019, 05:57 PM
amagras amagras is offline
That I can understand! Now I can say I agree even though I still need to hear more about how gain staging would relate to, or be relevant to for example, working with VIs or getting audio already digitalized.
Thank you very much, I appreciate all you guys taking the time to discuss this with me
I could use a more detailed explanation of this part.
Dell XPS 8700. Intel Core i7-4770 CPU @ 3.40GHz. RAM: 16GB. Windows 10 Home x64. NVIDIA GeForce GTX 645. NI Komplete Audio 6. Pro Tools Software 2019
amagrasmusic.com
Old 01-23-2019, 07:25 PM
If you think gain staging in the box doesn't matter, try over-driving a plugin by cranking another plugin that's ahead. I suspect that will change your mind
Old 01-23-2019, 08:33 PM
Top Jimmy's Avatar
Part of the art of recording and mixing is establishing your own personal references. That is, the volume at which you monitor, the position of your interface volume knob and the gain level at which you record to achieve your reference monitoring level at unity. Without establishing and sticking to your references, you'll basically be reinventing the wheel every time you start a new production. That's not a recipe for consistency and reliability.
VIs would still need to fall in line with proper gain structure to fall within your references. You don't want your VI to be super hot and then you have to pull the fader down 20dB. You want it to be in the ballpark at unity.
Every mixer I ever sent a song to either wanted just the files or a stripped down Pro Tools session devoid of everything except the regions in their tracks with the faders at unity. In each case, they want to hit play and hear a rough mix at unity. They shouldn't have to "pre-mix" the song to get an idea of it before they get to mixing. The only best way to do this (which makes the process of recording easier anyway) is for me to set preamp gains from the start to achieve this in the end. I'm not looking to get the highest signal to noise ratio without clipping, I'm looking to rough it in to where it belongs in the mix.
James Cadwallader
  #16
Old 01-24-2019, 01:19 AM
cwsand's Avatar
Yep, analog distortion is great - digital clipping? Not so much!
Help Us Help You
Chris
Pro Tools 2024.3
Focusrite LS56
Focusrite Pro40 (2)
Slate Digital VRS8
UAD Volt 2
macOS 10.15.7
32 GB DDR4 RAM
  #17
Old 01-24-2019, 01:40 AM
Sardi Sardi is offline
Only if desired.
  #18
Old 01-24-2019, 03:17 AM
I'm aware of that, I talked about it earlier
amagrasmusic.com
  #19
Old 01-24-2019, 03:20 AM
Thanks a lot Top Jimmy, this corroborates what I believe is correct too, very appreciated!!!
amagrasmusic.com
  #20
Old 01-24-2019, 03:22 AM
What is digital clipping?
How do you create it?
amagrasmusic.com
"A VST Wrapper is a VST Wrapper" True or False? DBK AAX Plug-ins 9 12-23-2014 09:38 AM
MIDI CC - True of False eitw Pro Tools 11 19 09-22-2014 03:45 PM
Eleven Rack / Avid is not producing anymore Eleven Racks is that true or false? Rongpat Eleven Rack 8 02-11-2014 07:42 AM
New G4...false alarm.. Seller Pro Tools TDM Systems (Mac) 19 08-27-2002 06:11 PM
Pro Tools 5.1: Does it sounds better? TRUE OR FALSE??? joy4u Tips & Tricks 7 03-07-2001 11:14 PM
