Go Back   Avid Pro Audio Community > Pro Tools Software > Pro Tools 2018
Old 01-06-2019, 01:23 PM
Cayce Cayce is offline
Default Imported MIDI Track Won't Show Note Velocity Colors
The Pro Tools Issue du Jour...
I have a group of MIDI drum tracks as a template I import into any new project. It has a main MIDI instrument track with a Superior Drummer insert. The individual instrument mics in Superior Drummer are assigned to separate Aux input tracks, via the main instrument track, so I can treat each separately. When I import this template into a project, even though I'm generating new MIDI notes, they won't show the velocity color variations, even after toggling that preference on and off. They're all one solid color.
Any known solutions for this?
Thanks.
Cayce
iMac (Retina 5K, 27-inch, Late 2015)
4 GHz Intel Core i7
32 GB 1867 MHz DDR3
2TB Internal Fusion Drive
2 4TB External Drives with Mirrored Backups
2 External Monitors: 27" & 65"
Old 01-11-2019, 09:16 AM
Benoni's Avatar
Benoni Benoni is offline
Default Re: Imported MIDI Track Won't Show Note Velocity Colors
Did you trash preferences?
Did you try a new blank session?
Old 01-19-2019, 02:23 PM
edwinstar's Avatar
edwinstar edwinstar is offline
Did you test check/uncheck „MIDI Note Color Shows Velocity“?
oops, sorry, you already mentioned that!
MIDI note off velocity musicman691 MIDI 4 06-09-2015 10:28 AM
Velocity colors all the same in imported MIDI chriskmon Pro Tools Express on Windows 0 03-12-2014 12:42 PM
Single MIDI Note Velocity Curve yvanhar Windows 1 07-24-2013 05:09 PM
Midi 101 really missing? Set high note/low note on track's input robinsonsdca macOS 4 11-10-2011 01:23 PM
Midi note velocity quantize on the fly: possible? seth666 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 09-13-2005 08:44 AM
