Go Back   Avid Pro Audio Community > Other Products > Pro Tools Express on Mac OS X
Old 12-12-2018, 07:45 PM
Chrisgandme Chrisgandme is offline
Default Can Pro Tools 8 LE download on newer Macbook pro
I’ve owned Pro Tools 8.0.4 LE for quite some time. My old Mac is failing on me, so I want to buy a new one, but I want to still use my old pro tools software. The question is will the new MacBookPros except what I have? I want to know what my options are before purchasing anything. If a Mac doesn’t work I’m willing to get a windows that will. Anybody know anything.
Old 12-12-2018, 07:58 PM
Default Re: Can Pro Tools 8 LE download on newer Macbook pro
Welcome to DUC.
The answer is: Nope. :-(
And Windows 10 is probably not an option either. And trying to downgrade as far back as you would need to go seems a waste of time.
You should work out how to answer these questions yourself, Google for “Pro Tools Systems Requirements” and find the info you need. In some cases we can give extra advice here about what might work if not officially supported.
And Pro Tools 8 LE would still require your legacy interface for licensing but you may not be able to get that interface to work even if Pro Tools does, All of which means getting onto a modern OS is the way to go.
Pro Tools 8 is not worth anything as an upgrade, you can buy Pro Tools or rent it by the month. Probably the best place to understand those options is Sweetwater.com.
Old 12-13-2018, 01:33 PM
YYR123's Avatar
YYR123 YYR123 is offline
Here is the chart for the people. Really good info here. This is the gospel, live or die by it.
https://avid.secure.force.com/pkb/ar...tibility-Chart
Daniel
How do I open older Pro Tools Sessions on newer Pro Tools systems? Michaelnacho Pro Tools 11 5 02-10-2017 08:24 AM
Pro Tools 9 on Newer Mac OS Stephen Reen II macOS 1 03-24-2015 08:58 AM
New Macbook and Pro Tools 9 Download dB_5 macOS 0 05-11-2012 06:42 AM
Digi support: Can I download newer updates for third party plugins than whats posted? Violet 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 05-06-2009 11:41 AM
