Old 12-10-2018, 04:50 PM
Eric Lambert's Avatar
Default Real time SR conversion via spdif - Avid HD IO
My session is at 48 but an external box is fixed at 44.1 so I'm trying to convert the external box's signal on the way in. I was pretty sure that the Avid HD IOs could convert on-the-fly at the spdif inputs, however, I don't seem to know how to get that working. Selecting sample rate conversion in Hardware Setup doesn't do what I need (the signal still has the incorrect sample rate distortion).
Any ideas? Maybe it won't convert spdif on-the-fly...
Old 12-10-2018, 05:09 PM
Top Jimmy's Avatar
Default Re: Real time SR conversion via spdif - Avid HD IO
As I recall, the real-time SRC only ever worked for inputs to the digital card, not the ones on the enclosure.
If you had an AES-Dsub cable, you might be able to use a balun to adapt the RCA to XLR. But, while this works just fine with many digital input receiver chips, I don't have first-hand experience with doing this on an Avid interface.
James Cadwallader
Hackintosh - Gigabyte Z77X-UP5TH, Intel Core i7-3770K, 32GB 1600Mhz DDR3, 2x SATA 6Gb/s 240GB SSD, 3x SATA 6Gb/s 1TB HDD, 1x Glyph 2TB USB3 HDD, Mojave 10.14.6.
Pro Tools Ultimate 2021.3, HD Native, Focusrite Red 8Pre (Mac)
Pro Tools 2020.12, Mbox3 (Win)
Old 12-10-2018, 06:06 PM
Yeah, I've thought about converting to AES but was hoping I could avoid that.
Another option is to use the toslink connectors on the hardware unit and the IO, a connector type which *might* offer real-time conversion in ProTools...? Hopefully?
Old 12-10-2018, 06:40 PM
Top Jimmy's Avatar
As long as the output box does ADAT optical you can apply the SRC when using the optical port on the card. Just know, the optical port on the card only does ADAT, it can't be switched to optical S/PDIF.
James Cadwallader
Old 12-10-2018, 06:56 PM
What is the "external box"? What are you doing with it? More info might reveal other options, like maybe record the external source to a 44.1K session, then open your 48K session and Import Session Data, and tell PT to apply SRC on import
Gigabyte X79/intel i7 3930K, 32GB RAM, Presonus Studio 1810C
I started in this business with nothing..........and I have most of it left
Old 12-10-2018, 07:23 PM
It's a UA OX guitar interface (a fantastic box, btw) and it can't output ADAT, only spdif. I could go analog but I'd rather not introduce another D/A and then A/D. I could convert spdif to ADAT with an adapter but that's an expensive product.
This is becoming more of a headache than I expected. My sessions will never be 44.1 -- always 48 or higher -- so something's gotta convert.
Old 12-10-2018, 07:45 PM
S/PDIF to AES/EBU is likely the easiest path...
Old 12-10-2018, 08:40 PM
That's my thought, too. I just want to verify that the Avid HD IO will do realtime SR conversions if I connect via AES.
Old 12-10-2018, 08:44 PM
YYR123's Avatar
YYR123 YYR123 is offline
This is true
Daniel
Old 12-10-2018, 08:54 PM
I don't have the added digital IO card, so... that means I'm out of luck with the realtime conversion idea?
Spdif RCA to Spdif Optical conversion - degradation?? Hollow Body 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 0 02-17-2011 08:21 AM
Real-Time Bounce to Disk...REAL PAIN Brian in Charlotte 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 201 07-26-2010 08:12 AM
File Conversion-W/O real time play down STUDIO 44 Pro Tools TDM Systems (Mac) 4 08-26-2005 01:54 PM
real time Sample Rate Conversion nukmusic 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 3 11-15-2004 06:46 PM
Capture range for real time SR conversion KK Proffitt Pro Tools TDM Systems (Mac) 0 10-19-2004 01:44 AM
