Go Back   Avid Pro Audio Community > General Discussion & Off Topic > General Discussion
Old 11-28-2018, 08:30 AM
bayside bayside is offline
Default Keyboard doesn't control PT functions
My PT keyboard doesn't control PT functions, start stop ect. What could be up.
worked yesterday
Old 11-28-2018, 10:19 AM
Benoni's Avatar
Benoni Benoni is offline
Default Re: Key Board
So Space Bar doesn't work... or are you referring to the Command Focus shortcuts?
Brian
Windows 11 Pro | macOS 12
Pro Tools 2022
benonistudio.com
Youtube Channel - benonistudio
Plugin Deals
@benonistudio
Old 11-28-2018, 12:55 PM
Default Re: Keyboard doesn't control PT functions
Do you have any plugins open on the screen? Some of them(Toontrack for instance) will take over the keyboard until you click outside of the plugin(to re-focus the keyboard back to Pro Tools).
Does the keyboard work outside of PT?
Old 11-29-2018, 05:19 AM
worked yesterday
Could you give us some system info? Laptop or desktop computer?
Does the keyboard work at all for regular computer functions?
Wired or wireless keyboard? If wired is it plugged into a working & powered up USB port? If you're on Windoze the default is to have USB ports power down after a while. That can be corrected by going into Windows Control Panel and turning off all power savings measures for the USB ports. If wireless is the battery charged? Also if wireless make sure the keyboard & computer are paired.
Jack
QAPLA!
Old 11-29-2018, 09:41 AM
Benoni, no the space bar doesn't work from the avid keyboard usb connected.
The keyboard does some function on the lap top.
System;
MacBoxPro 10.8.5
PT 11
Artist Mix
Avid keyboard
2 Apollo 8's
blue tooth mouse
Old 11-29-2018, 10:53 AM
System;
MacBoxPro 10.8.5
PT 11
Artist Mix
Avid keyboard
2 Apollo 8's
blue tooth mouse
What is a MacBoxPro? Do you mean MacBookPro instead? If so does the laptop's own keyboard function as it should in PT?
Does the PT keyboard work normally in other programs?
Jack
QAPLA!
Old 11-30-2018, 03:26 AM
Musicman . . . Mac book pro. The avid keyboard works on certain functions,enter,close window and others. Space bar does work at all.
The keyboard does control some functions on other programs.
OK sessions are loading and recording. Can only create 1 track at a time and space bar doesn't work. Lap top keyboard does work.
Old 11-30-2018, 04:14 AM
Being the laptop's own keyboard works okay in PT then the fault is NOT with the PT program but the so-called PT/Avid keyboard which is really nothing more than a standard Apple keyboard with different keytops to show the shortcuts. If you look at the underside of the keyboard I bet you'll see the Apple logo. PT doesn't know or care which keyboard that's being used. Make sure that both the laptop and external keyboard are recognized by OSX as the same type of keyboard. See this page: https://thetypingcat.com/howto/chang...ayout-mac-os-x
For clarification: does the external keyboard work okay if you use it for normal everyday functions like you would use the laptop's own keyboard? Not just some functions but for everything?
Jack
QAPLA!
Old 11-30-2018, 04:38 AM
No, the avid board won't type letters or numbers. I',m going to follow on your suggestions. Oh, everything was fine until 3 days ago.
Old 11-30-2018, 09:55 AM
Okay, that pins the problem on the keyboard. Check its connection and maybe try moving it to another USB port.
Slow functions on the Artist Control w/ PT Control firmflange Artist Series 15 11-26-2018 10:27 PM
Transport Functions C600 doesn't work hollow Pro Tools 11 1 08-16-2013 07:12 AM
Keyboard functions PT10 on MacBookPro KSD macOS 4 03-20-2013 06:40 AM
Lost Keyboard Functions Some Or All Help wolfman_rob Pro Tools TDM Systems (Mac) 2 05-15-2008 03:43 PM
What functions in PT can you control with an 02r? saloniki MIDI 2 12-01-2005 10:33 AM
