Old 09-21-2018, 06:54 PM
LDS LDS is offline
Default 5.1 to Stereo, Stereo to 5.1 and your Mix Templates in Pro Tools
Hey everyone,
I am curious how you handle your Pro Tools sessions in terms of projects that require (or even may require) multiple playback formats. i.e, Stereo and 5.1 versions. Do you work off two separate mix templates for each, or have you set up a single template that effectively allows you to do either depending on the request.
I am working on a project (dialogue edit, sound design & mix) at the moment where it is up in the air if it will end up as a full 5.1 surround mix, perhaps just an LCRS mix for screening purposes, or stereo. In all likelihood, it is going to end up in 5.1 and stereo...
Any advice on how you would handle such a project? It seems easier, at least from a sound design perspective to start with 5.1 and work it down if needed... rather than heading from stereo up to 5.1. Would anyone have a mix template they might like to share?
littledevilstudios.com.au
Pro Tools Ultimate 2019.6. OSX 10.14.6. HDX. Avid Omni. MacBook Pro 2018. 6 Core i7. 32Gb. 4x mSata SSD Drives + 4x HDD. Blackmagic Intensity PCIe. ATI RX580. Sync HD
Old 09-21-2018, 11:25 PM
its2loud its2loud is offline
Default Re: 5.1 to Stereo, Stereo to 5.1 and your Mix Templates in Pro Tools
Start with widest format (7.1, 5.1, etc.) and downmix from there. Making a template is easy. Create your 5.1 busses and any sub busses you may need for Dialog, Music, FX, etc. Create downmix stereo busses and auxes for the same using the built in downmix plugin. Assuming you only need an LoRo. If you need an LtRt then you’ll need an encoder plugin (Neyrinck)
Create your source tracks and route accordingly.
HTML code is On
Dragging non interleaved stereo clips to stereo track changes pan [SOLVED] dalonso66 Pro Tools 11 0 06-02-2016 11:03 AM
Installer WANTED:Neyrinck SoundCode Stereo surround-to-stereo down-mixer Ale Pro Tools 10 3 08-14-2012 10:05 AM
Routing to give a stereo group a stereo plugin on the VENUE plus AES EBU uses somtech VENUE Live Sound Systems 5 05-19-2012 07:43 AM
Cueing Stereo Channel with one Wedge and Reversing Phase on a Stereo Aux 0675477985@orange.fr VENUE Live Sound Systems 1 11-20-2008 05:29 PM
connecting 001 to a home stereo to A/B between mixing monitors and stereo speakers... Siberian 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 3 04-10-2003 12:14 AM
