Old 09-01-2018, 10:56 PM
Mattian Mattian is offline
Default 10.13.6 with 2018.7 ... best version ever!? Holy Sssh
Ok guys, I have to give you a good news, at least it seems so
I’ve spent an entire day installing osx versions and pt 2018, here are the results, unfortunately you just have my word, I didn’t do videos or stuff (didn’t have time, to many things to pay attention to avoid screwing things up)
Setup was two identical usb 3 external hd (sorry, I only had them, so they surely affected the performances in a wrong way, but they were the same, so they null)
I’ve installed Sierra 10.12.6 on one hd and High Sierra 10.13.2 (thanks to TNM) on the other... they seemed to work the same exactly the same
I’ve loaded a mix I was working on in pt 10.3.10, using 256 of buffer and 96k sample rate
No hiccups at all, pretty snappy, also graphics, the biggest problem was the hd (also because both the OS and PT were in the same hd, so pretty extreme situation)... not as snappy as using the internal apple ssd, I tried to start and stop very fast moving around the session to stress the system and sometimes I got the error “not enough fw bandwidth, even though is usb3 xD)... but very workable, and I was impressed by graphics, meters, were very fluid
So I updated to 10.13.3... things remained the same as before
No version could handle 128 buffer at 96k (I’m talking about a full mix here BTW, not too many plugs, no VI but automations and stuff, 64 tracks with a lot of cuts, fades, stretched stuff)
And now it becomes funny xD
I installed 10.13.6 combo update:
- is the only one that handles 128 as it was 256 in the other versions, and can do 64, I mean you get the error, but I’m almost been able to do a full playback of the song from start to end
- It seems to have a lower cpu usage, 5/10% less
- It is the snappiest combo and everything is more fluid, steady... and I haven’t even tried it in an internal hd, I’m so curious to try it out in the internal ssd!
And now you really wanna laugh xD
So, in the end I booted Mavericks 10.9.3 with PT 10.3.10...
At 256 of buffer it was unusable... I got 4 error because of cpu spikes in 30 seconds of playback
AND IT WAS INSTALLED IN THE INTERNAL APPLE SSD
So, that’s it, it is not a deep test, but those are the findings, then I don’t know if working with it daily it’ll go crazy or will have other problems... but so far, with 10.13.6... wow, seems reeeally solid and snappy... also 128 of buffer on a full mix when I had to keep 1024/2048 to work with it in pt 10!? Never been able to do that
I thought 10 was the best version, but wow, this seems totally another level
And guys, I’ve been pretty pissed off by avid in the past, I also wrote them some heavy words cause I was really pissed off
So I don’t know way avid doesn’t support 13.6, maybe for some other reason, I don’t know, and I hope to not be there tomorrow moaning about how ****ty it is and how wrong I was, but man... this seems really on another level compared to 10 and much better than all the other OS I tried in this test
Old 09-02-2018, 02:55 AM
Emi's Avatar
Emi Emi is offline
Default Re: 10.13.6 with 2018.7 ... best version ever!? Holy Sssh
I to believe it’s a good combo. Works great here, even at 192khz. Sometimes I have the feeling I’m recording on a hardware recorder or tape machine. Lovely!
Mac Mini M1 | Mac OS 12.6.1 Monterey | Avid Carbon + 2x Carbon Pre | Pro Tools Studio 2024.3
Old 09-02-2018, 01:55 PM
innesireinar innesireinar is offline
Interesting... coud you give us more specs about your system? Machine, audio interface, ram...
Avid HDX - Avid HD I/O 16x16 Analog - Pro Tools Ultimate 2023.6 - Nuendo 11
Mac Pro 5.1 2 esacore 2.66 64GB Ram - Mac OS 11.7.7
Old 09-02-2018, 05:32 PM
MacBook Pro mid 2014 16gb of ram, I have two metric halo lios-8, but to test it I’ve used the mb internal audio interface, but it doesn’t matter because I tested all the setup in the same way, and also how it played pt 10 with the LIOs or with the internal audio interface, was the same, or pretty much, I mean it didn’t matter for that purpose to use the LIOs, and I was more comfortable in the dining room xD
Let me know if you need more infos...
Oh well, I didn’t have installed any plug ins except for the metric halo production bundle... the mix had only them, and I use only them plus the lexicon pcm and sometimes some other avid plugs, nothing else installed in the system, but again, that was the same for all setups I tested
Old 09-02-2018, 11:16 PM
xrekcor's Avatar
xrekcor xrekcor is offline
running rock solid here too.... I should also say.... just in case, I'm not updating again my OS until its supported or enough users are using it issue free.
Rob
MBP 15” 2018 macOS Big Sur 11.6.8 Touch Bar and ID
2.2GHz 6 core 8 gen Intel Core i7 processor (TB’s to 4.1GHz)
32 Gb of 2400MHz DDR4, 1T SSD, Magic Mouse and Keyboard
Pro Tools 2022.7 -23.# - HEAT applied, RME Fireface UCX II
........and a bowl of M&M's
Old 09-03-2018, 04:11 AM
I love you man... by updating to 10.3.6 the CPU I no longer have spikes.
I think that was a graphic issue because by closing the edit window the sparks went away as well. BTW now it seems that the 10.3.6 has fixed this. Don't understand why Avid is still on the 10.3.3 recommendation
Old 09-03-2018, 05:20 AM
KV626's Avatar
KV626 KV626 is offline
I just got a new gpu so my Mac Pro is now Mojave-ready, and since it will require High Sierra before installation, I reinstalled HS a couple days ago. I have worked with several sessions since then, and I have to agree, I'm suprisingly pleased with High Sierra this time around and PT is going very smooth!
Mac Pro 5,1 (Mid-2012) 12-core 2 x 3.3 GHz / MSI RX 560 / 40GB ram / macOS 10.14.5 / Pro Tools 2019.5 / Logic Pro X 10.4.4
Arturia Keylab 88 Presonus Faderport 8 MOTU 896 iPad Air 2 w/ PT Control
NI Komplete Ultimate 11 • Albion One • Soundiron Choirs • Pianoteq • Analog Lab • VSL SE/Chamber Strings • etc
Old 09-03-2018, 06:35 AM
10.13.3 was a nightmare with PT. At least with the HDX.
Old 09-03-2018, 07:38 AM
JFreak's Avatar
JFreak JFreak is offline
Best version ever was PTHD 8.1.1 on OSX 10.6.8 (stability-wise)
Janne
Old 09-03-2018, 10:31 AM
toolz toolz is offline
This is awesome news ) as you know, I've been plagued with the same issue as you )
[B][SIZE="1"]System:
PT 12.8.1 HD-Native PCIe, 48 I/O 16x16, 2012 Mac Pro 12 core 3.46Ghz 64gig RAM, UAD Quad FW, Apple 30” Cinema
Is Pro Tools 2018 EVER going to be supported on a current Version of High Sierra? off the wall macOS 10 01-05-2019 04:53 PM
Macbook Pro 2018 w/ UAD Apollo 8p and PT 2018.7 Performance Issues Dudiester Pro Tools 2018 5 08-12-2018 08:33 AM
Pro Tools 2018.3 / 2018.4 crashing when switching window configurations matthewmkb macOS 0 06-27-2018 06:33 AM
Permission Denied (13) on Launch -Pro Tools 12, Version 2018.1 Randroo Pro Tools 2018 7 05-07-2018 08:11 AM
Does the 2018 boxed version come with iLok 2 or 3 and ... rique000 Pro Tools 2018 3 02-23-2018 06:11 PM
