Go Back   Avid Pro Audio Community > Pro Tools Software > Pro Tools 2018
Old 08-22-2018, 01:29 PM
XJENSEN XJENSEN is offline
Default Serious issue with HW inserts and LLM enabled
Hi everyone,
Last week I filed a support case regarding HW inserts and LLM (Low Latency Monitoring).
As usual, it takes some time before Avid support recognises anything as a bug, so I thought I'd seek some confirmation and/or help here in the mean time. Any thoughts are highly appreciated.
My current setup is:
  • HD Native PCIe system on Mac Pro (Mid 2010)
  • one HD OMNI
  • one HD I/O 8x8x8
  • Protools HD 12.7.0 on MacOS Sierra.
The Mac’s optical output is connected to the optical input of the HD OMNI and is transmitting 2ch, 96kHz, 24 bit digital audio.
On the 2 channels coming from my Mac, I have separate, mono HW inserts (channels 7 and 8 on the HD I/O). This all works perfectly when LLM is not enabled.
However, when LLM is enabled, I am experiencing very odd (and frankly, annoying) behaviour:
  • With any of the L/R channel HW inserts enabled, PT starts sending audio L and R at random. Or it doubles up the L mono channel to both L/R on the speakers. In LLM mode, where PT decides to send the audio to, seems to depend on a random pan pot position on some random other track. In other words, some other track's pan seems to control the post-fader pan of the track which has the active HW insert.
  • The pan pot on the LLM track seems inoperable when a HW insert is activated.
  • Even the fader on the LLM track seems inoperable when a HW insert is activated.
Am I missing something obvious here or is this a serious (maybe well-known) bug? Can anyone reproduce?
I would also be interested to learn whether this behaviour also exists in later versions of PT HD/Ultimate.
Cheers,
Xavier
Old 08-28-2018, 03:34 AM
Default Re: Serious issue with HW inserts and LLM enabled
Well, I got a reply from Avid support: Pro Tools 12.7 is not supported on OS X 10.12.6. This can be the main reason for the issue.
Pro Tools Compatibility Chart
No sound from record enabled track when low latency monitoring is enabled ncsaxman Pro Tools 12 13 06-22-2019 01:35 AM
Solution to "Track could not be record-enabled" issue with PT10 and Eleven Rack spankyq Pro Tools 10 8 04-20-2015 08:19 AM
HD I/O and Hardware Inserts Issue esmallwood Pro Tools HDX & HD Native Systems (Mac) 4 09-20-2013 01:13 PM
OMNI inserts only for mic pre , or used as master buss inserts as well Weird Audio Pro Tools TDM Systems (Mac) 3 11-14-2012 09:27 PM
002 Surface issue - Faders snap to 0 when Record Enabled, Firmware? Table Syrup Records 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 05-28-2009 11:25 AM
