Old 05-26-2018, 08:06 PM
filbasco filbasco is offline
Default Midi I/O problems with installers
Please could I ask for someone's assistance. I am running Pro Tools 7.1 on Mac OS X 10.4.8. I am running Digidesign Midi I/O 10 port midi device.
I recently got a second device and found that I need to install the software so that both can run. I went to the AVID site and downloaded the drivers for OS9/10 for ProTools from the AVID site making sure to follow the instructions.
When I install it, it does not work from the location where it is installed there is a circle with a line through it and it won't launch. When i try to launch I get the message: "You cannot open the application "Midi IO Setup" because it is not supported on this architecture" or on the firmware updater, "You cannot open the application "Midi IO Firmware Updater" because it is not supported on this architecture".
Any and all assistance greatly appreciated as I have absolutely idea what the problem is.
Old 08-30-2018, 10:07 AM
Grey Grey is offline
Default Re: Midi I/O problems with installers
unplug MIDI io before installing.
You may need Firmware update
I have had troubles with my MIDI I/O also.
Hope this helps
http://akmedia.digidesign.com/suppor...d_Me_29761.pdf
Where did the 12.7.1 installers go? rhumphries Pro Tools 12 3 06-26-2017 02:30 PM
DUY INSTALLERS - Please Help! psmworld Windows 15 10-12-2015 11:48 PM
DUY INSTALLERS - Please Help! psmworld Pro Tools HDX & HD Native Systems (Win) 9 04-21-2012 11:02 AM
Midi Studio Setup problems & Plugin problems J Nauti MIDI 0 03-02-2010 11:04 AM
