Old 05-11-2018, 12:51 PM
aftermid aftermid is offline
Default HDX Omni Makes Digital Distortion in Mirror Mode
So I was troubleshooting a board I have, where there is D25 connector from the omni that breaks out to eight xlr cables going to the board. I noticed the left side of the mix would drop in and out. To rule out the board, I connected the TRS Mirror outputs directly to my amp bypassing the board. When I Click TRS Mirror for outputs 1-2, I get a horrible digital distortion sound, like a feedback. I then tried TRS for outputs 7-8, this works sometimes and sometimes same distortion. If I uncheck the Mirror option, distortion stops. The DB 25 pin connector is still connected to board in question. I can see the inputs LEDs going crazy on the board, which tells me the DB25 is still sending the digital distortion to the board. I don't hear it, because my board is now disconnected from amp. The only thing that is going directly to the amp is the TRS outputs of Omni.
This just started, never happened before. I've tried restarting computer and Omni, which stops it temporarily, until you try the mirroring again.
Any ideas? Has anyone had this happen using the TRS mirror option on setups?
Old 05-15-2018, 09:43 AM
DetroitT's Avatar
DetroitT DetroitT is offline
Default Re: HDX Omni Makes Digital Distortion in Mirror Mode
In Pro Tools Setups>Hardware there is nominal gain for speaker setups.
Test the db25 for broken connections.
Level match you components. +4. -10 etc...
Specs in manuals.
(Help us Help You)<<<click here
APFS 90% 10% Audio on Both.
Pro Tools U-2020.9.1 macOS 10.14.6 APFS
Second boot-macOS 10.13.6 (Avid HDX-1 Omni)
Third boot 2K19MP 10.15.6
(2k10MP 5,1 / 64-Gb)
(Sapphire RX-580 MVC-Edition-dual mini 6 pin. one spliced to add Avid mini 4 pin-hdx)
FW-CoreAudio (for poly-recording)
(SSL-HUI-MIDIoverIP)
music-design-creation
Post Music-Sound mixing, Production-Enhancements.
Audio Tuning and System Services
new systems builds / upkeep / +
Mirror Analog and Digital out HD Native + OMNI jameshil Pro Tools HDX & HD Native Systems (Mac) 4 03-29-2017 05:29 AM
Mirror analog and digital audio out on a Mac Pro running 10.6 Craig F macOS 0 05-20-2011 07:00 PM
CoreAudio 7.3: Mirror analog outs 1&2 to digital ous helios69 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 10-05-2007 09:49 AM
Core Audio Manager refuses to quit, mirror to digital outs max cooper 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 08-16-2007 04:24 PM
Control 24 makes loud pop or digital distortion? jammanis ICON & C|24 4 04-27-2006 05:06 PM
