Go Back   Avid Pro Audio Community > Pro Tools Software > Licensing & Accounts
Old 05-02-2018, 03:38 AM
tklaavo tklaavo is offline
Default Cannot update billing address
Hi, I have read some others have also had similar issues. I am trying to activate the complete plugin bundle licenses that come with our PT ultimate subscriptions. This is what happens:
- I sign in at avid.com
- navigate to "products not yet downloaded" section
- what I see there is "Avid Complete Plug-in Bundle - annual (Qty: 2)" and a button "Activate product"
- I click "activate product" and the window opens, where the Code field is already populated with a code.
- From there I click "activate product" and get this message: "Your billing address needs to be validated before you can continue. Please visit this page to update and verify your information."
- I click the link and the update billing address window opens
- All the information is good so I click "Confirm" without changing a thing
- I get a red error under the "State / province" field: "Billing country and state cannot be changed because you have active subscriptions"
- both the country and state fields say "FINLAND" which is correct.
- there is no way to get past this.
I have opened a support case, and so far have not gotten any helpful answers. I am getting frustrated, this shouldn't be too difficult to fix
A couple of other threads with similar troubles:
http://duc.avid.com/showthread.php?t=398920
http://duc.avid.com/showthread.php?t=398924
T
Tuomas Klaavo
Helea Sound Post Production Oy
Old 02-19-2020, 02:18 PM
morrisoc morrisoc is offline
Default Re: Cannot update billing address
Got a fix for this issue as it is still happening in 2020!
So the problem. I logged into my Avid account to activate a Eucontrol licence however, when submitting a message appeard telling me to update my billing address even though it was correct. When the update window opened, the 'state' field was blank so selected the correct option and submitted but the system came back with the message "Billing country and state cannot be changed because you have active subscription". At this point you are stuck in a loop and unable to activate something that is already paid for. Checking out the forums most people said it took days for support to resolve so excited to play with my new tech I came up with a workaround!
The workaround.
Head to the Avid store while logged into your account and add something to your cart (can be anything, I just added a coffee cup) then hit checkout. When the window opens it will ask you to enter your payment and billing informaiton. Confirm your existing credit card info then in billing address section dont update what is displayed but instead use the drop down selecting add new then enter your billing address information again. When its complete hit next to take you to the shipping screen - don't worry you are not charged for anything at this point and you can close this window heading back to the activation screen (or whereever you had this problem) and again you will be prompted to update your billing address. This time however, you should have a dropdown allowing the option of selecting the new one you just entered! Submit that and your done !
Hope this helps you also!
Last note: I am based in Victoria, Australia and for whatever reason it just would not accept my state so just used a differnt country and address to work around this issue then removed afterwords.
Cannot Verify Billing Address RETorres Getting Started 2 04-29-2018 04:24 AM
Can't update my billing address for invalid Zip code format jinwookpark Licensing & Accounts 2 04-05-2018 07:42 PM
Cannot update my billing address... SlinkStudio Licensing & Accounts 1 09-06-2017 03:24 PM
Can't download protools because Avid wants me to update billing address Recording Room Pro Tools 12 12 04-26-2015 10:46 AM
