Go Back   Avid Pro Audio Community > Pro Tools Hardware > Third Party Interfaces
Old 04-10-2018, 11:50 AM
Jeddr Jeddr is offline
Default Apogee Ensemble Thunderbolt - Routing issue for outputs 9 & 10
Good evening,
I have a Apogee Ensemble as a main interface for Pro Tools. I seem not to be able to setup my inserts 9 & 10 properly. I'm using the latest Apogee Control sofware
Here's what's up, so far:
- Ensemble has it's outputs 1 & 2 reserverd for the main monitor outputs
- Ensemble has 8 outputs (3 to 10) on a D-Sub Cable
- Ensemble only has 8 physical line inputs, which are inputs 1-8
- Pro Tools IO setup has "Insert 9-10" linked to the ensembles 9-10 line outputs. PT expects Inserts to come back in on the same Line inputs, being input 9-10
- Inputs 9-10 are the talkback mic on the interface, so I'm using inputs 1-2 to return to the interface. Since those are the only free one's left.
- Apogee Control doesn't seem to have a matrix (like older versions did) to change the internal routing so that I could actually reroute inputs 1-2 to software inputs 9-10 in Pro Tools.
Question, how did anyone of you manage to use insert 9-10 with the Apogee ensemble.
Thanks so much for your time.
Alex
Old 02-18-2020, 12:51 PM
Jscotti Jscotti is offline
Default Re: Apogee Ensemble Thunderbolt - Routing issue for outputs 9 & 10
I believe you can only use the hardware inserts on input channels 1 & 2 on the Ensemble, and you cannot assign them to other channels.
Apogee introduces new Ensemble Thunderbolt nst7 Third Party Interfaces 25 09-22-2016 02:13 AM
Apogee Ensemble Thunderbolt - end user experience Matt Darcy General Discussion 16 04-20-2016 07:49 AM
Help with Output Routing PT 10 and Apogee Ensemble. jmilkey Pro Tools 10 1 10-12-2015 07:30 PM
input 11-12 on apogee ensemble thunderbolt not displaying in protools 11 Matt Darcy Pro Tools 11 3 09-13-2015 01:35 PM
Protools 9 and Apogee Ensemble Thunderbolt smilch Third Party Interfaces 1 12-13-2014 11:03 AM
