Old 03-21-2018, 01:38 AM
Rockman413 Rockman413 is offline
Default what's this 2 green arrows in the wave?
Hey guys,
I exported a wav from DP and import it into Pro Tools HD. After import I see two green arrows in this waveform with an extended starting empty region.
The green arrows marked the starting position of the original wave, anything before the green arrow are added/extended region... Why would this happen, what does this mean? Is this advanced funtion I don't need?
Thank you
Mac Pro 3.0G 8 Cores PT HD use with Ensemble Thunderbolt
Old 03-21-2018, 01:54 AM
BScout BScout is offline
Default Re: what's this 2 green arrows in the wave?
Those are sync points. DP must embed them in export and ProTools reads it. You can hide (view>clips>sync points) or remove by highlighting the clip, Clip>remove sync points (or command+comma)
Pro Tools Ult 2020.11, HDX 3, MTRX/SPQ, HD OmniMac Pro 5,1 - 3.06 GHz 12 core - macOS 10.13.6RAM 64GB, SSD 4 x 2TB, GPU GTX 980 4GB
up and down arrows and delay compensation reflexson Pro Tools 12 0 03-18-2017 06:22 PM
red arrows- can't edit bifbangpow Pro Tools 11 3 07-14-2015 01:35 PM
Green arrows in Beat Detective? kirkbross 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 11-28-2014 06:53 PM
Fades window/arrows matmi ProControl, Control|24, Command|8 0 08-31-2005 05:00 AM
arrows gira29 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 02-12-2004 06:10 AM
