Go Back   Avid Pro Audio Community > Other Products > Storage Subsystems
Old 10-27-2017, 06:03 AM
Rockman413 Rockman413 is offline
Default If I use a crap HD to copy audio files, would it cause any problems?
Hi there,
Just wondering if I use a crap/old/ may have hit/ may have bad clusters/may have bad blocks hard drive to copy pro tools session/ audio files to another computer, will the receiver got affected/damaged audio files?
Is it as long as we can read/copy out from the crapped hard drive, then it's fine?
I have used an USB stick to copy audio files and I occasionally found 1 audio file got affected/damaged, half of that audio file turns into white noise... Not sure if it's the same with hard drive
Mac Pro 3.0G 8 Cores PT HD use with Ensemble Thunderbolt
Last edited by DigiTechSupt; 11-04-2017 at 07:42 PM. Reason: Duplicate threads merged and moved to appropriate forum.
Old 10-27-2017, 06:24 AM
Horns-Up's Avatar
Horns-Up Horns-Up is offline
Default Re: If I use a crap HD to copy audio files, would it cause any problems?
If the disk is old but fully functional, then go for it...
BUT
If you know that the disk may have bad sectors, do yourself a favor and throw it away. Disks are so cheap these days that it's not worth it to have your data (any data) corrupted.
You can get a 2 TB disk for about $60 on Amazon... put it in some USB enclosure and there you have your disk to transfer your sessions from one location to another.
Chris M.
Horns-Up
- Mac Pro (Mid 2010) - OSX 10.13
- Pro Tools 2018.4
- Apogee Ensemble - Firewire
- Eleven Rack
Old 10-27-2017, 06:50 AM
BUT
How about SSD? Would a old/may have hit SSD cause any corruption?
Old 10-27-2017, 06:55 AM
BUT
What's the best HD check soft? So maybe we can check if we suspect a HD
Old 10-27-2017, 07:23 AM
Horns-Up's Avatar
I got my first SSD back in 2008-2009 and it is still working perfectly fine.
I've been using it for different purpose over the years and it's quite possible that is has some bad sectors...(never checked it)
SSDs work a bit different than regular HDDs...
SSD can totally tolerate bad sectors because the firmware of the SSD keeps track of all bad sectors and will never write any data to those sectors.
If you are on windows you can use chkdsk or Disk Utility on Mac.
Chris M.
Horns-Up
- Pro Tools 2018.4
- Eleven Rack
Old 10-27-2017, 08:22 AM
meaning, if it has been written already, then a already-written sector turns bad, it will not be readable? Or it will still be readable, but you're going to get incomplete info/ corrupted audio?
Old 10-27-2017, 08:32 AM
JoelG's Avatar
JoelG JoelG is offline
Short answer, do yourself a favour and don't use a drive that has known bad sectors.
You can use a program to check the SMART attributes of a drive: https://www.passmark.com/products/diskcheckup.htm or run a full scandisk.
Joel
Jame Space:
HP Elite 6300 / Core i5 3570 / 12GB RAM / Win 10 Pro
Pro Tools 12 HD / Focusrite 18i20 + M-Audio ProFire 2626
Home:
Intel S5000PSL / 2 x Xeon E5450 / 32GB RAM / Win 10 Pro
Pro Tools 12 HD / M-Audio Project Mix IO
Rig:
Eleven Rack / ART SLA1 / Fender Mustang V 412 / FCB1010 w/ EurekaPROM
Old 10-27-2017, 09:42 AM
Joel
Is there a mac soft to check this?
Old 10-27-2017, 10:02 AM
john1192 john1192 is offline
here is a search for what you need .. Apple Disk Utility is one and then below that are others ...
https://www.google.com/search?client...UTF-8&oe=UTF-8
OS 10.12.6 for PT 11.3.2 & 12.4 & above
Mac Pro 6-core 3.33ghz (2012) 24gb ram 256gb SSD
Macbook Pro july 2014 2.5ghz 16gb ram 512gb SSD - OS10.12.6 - PT 12.4 & above
lynx AES16e-SRC & Aurora 16
Artist Transport & iPad - Pro |Control - EuCon 3.7 (older Euphonix Branded MC Transport)
Old 10-27-2017, 10:20 PM
I'm not asking how HDD or SSD manages sectors.
My questions are:
1. If an HDD/SSD have bad sectors, I use it to transfer files to my other computer, will my other computer get any corrupted files?
Or
As long as my other computer can read/copy the files without any errors, then I can fully trust all copied files are non-corrupted ?
2. If I write files to a good HDD/SSD, and later it got hit the ground/got damaged and may have new or even a lot of bad sectors- meaning my previously written files are now on bad sectors. So I copy them out to my other computer, am I going to get corrupted files? or as long as I can copy them out without any error, all files are exactly the same as the original fils?
Missing Audio Files in Session Copy jshiffma Pro Tools 12 5 06-20-2017 04:43 AM
Save Copy as without Audio Files force76 Pro Tools 11 3 11-20-2014 10:06 AM
How to copy audio files not in session folder? jchan Pro Tools Software (Mac) 2 04-18-2014 06:29 AM
Help! PT wants to copy all audio files PT10-PT9 evs Post - Surround - Video 2 07-23-2012 01:17 PM
How do I copy and paste audio files? tioluis Pro Tools TDM Systems (Mac) 4 07-01-2007 11:22 AM
