Old 07-28-2017, 11:52 PM
santoorman santoorman is offline
Default Midi Merge off, not making new clip
I have midi track, already have a midi clip. Midi merge is off. Loop playback and record is off (and so is destructive and quickpunch record). Also tried dynamic transport on and off.
When I record this midi track, it doesn't create a new midi clip, it is updating the existing clip. I have Midi merge off so I am confused what it's doing this.
I want it to create a whole new midi clip when I record in this mode.
anyone know what's going on? thank you.
Old 07-29-2017, 10:38 AM
SigFriedChicken's Avatar
SigFriedChicken SigFriedChicken is offline
Default Re: Midi Merge off, not making new clip
Try re-enabling loop record, while keeping midi merge disabled.
Old 07-31-2017, 10:40 AM
thanks, not working...
Old 07-31-2017, 11:34 AM
lesbrunn's Avatar
lesbrunn lesbrunn is offline
Yes, I noticed this too. You only get one long clip, which keeps updating as you record/edit, regardless of start and end boundaries that you create. Wasn't like that before, and it's annoying. I only noticed this in 12.8.
X99 | i7 5960x @4.6GHz | 64GB GSkill DDR4 | Nvidia GTX 950 | Samsung 950 Pro NVMe 256GB | Samsung SM961 NVMe 1TB | Samsung 850 EVO 1TB | Samsung MZ7PD256 SSD 256GB | Kingston 120GB SSD | WD Black 1TB x2 | G-Drive 4TB x2 | WD Elements 4TB | Audient ID14 | PT2020.12 | Windows 10 Pro
Old 08-22-2017, 11:31 AM
very annoying. i remove old clips, and then I record, if the record goes over an existing clip, it overwrites it. can't undo it without undoing the new clip that was created...
anyone know how to get this to work properly?
Old 08-22-2017, 01:06 PM
lesbrunn's Avatar
I generally ignore it and separate the clips if I want them that way.
Old 08-24-2017, 10:30 PM
Cosme422 Cosme422 is offline
Switch the view from clips to another option, maybe "notes"
Disabling Pro Tools from making extra copies of a MIDI Clip??? ProMac07 Pro Tools 10 2 12-01-2012 06:49 AM
Midi merge paldry macOS 0 10-11-2012 08:52 PM
MIDI Merge RoxyRiot Pro Tools 9 2 03-31-2012 12:24 AM
MIDI merge trakbytes ICON & C|24 1 07-03-2008 11:30 AM
MIDI Merge Denkelag 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 5 04-17-2007 03:44 AM
