Old 04-26-2017, 01:48 PM
nedorama nedorama is offline
Default Terminal App Opening Randomly? Thank Avid's Application Manager
https://origin-discussions-us.apple....art=0&tstart=0
If you're noticing that Terminal opens randomly on your Mac for no reason and you've run BitDefender and other virus checkers to no avail, look no further than Avid's Application Manager, which does this.
Really wish the developer team would check their work before submitting out in the wild, but that would take time and resources...
Avid - please fix this or just kill the Application Manager. You only get so many tries to get a simple app right.
Regards,
Ned
Monkey Boy Studios
2019 16" MBP, 32GB, 1TB SSD; OSX 10.15.7; 4TB USB-C G-Tech External
Summit Audio 2BA-221, TLA-50 -->Focusrite 18i20 3rd Gen, Eleven Rack, Pro Tools 2021.3
Plugins, Virtual Instruments, and real ones
Old 04-26-2017, 02:16 PM
john1192 john1192 is offline
Default Re: Terminal App Opening Randomly? Thank Avid's Application Manager
hey Ned, if you are NOT using the App Man .. then just toss this .. Mac/Library/launchagents - toss the App Man file .. !!! now it will not launch ... terminal should not open ..
john
Mac Pro 6-core 3.33ghz (2012) 24gb ram 256gb SSD -OS 10.12.6 for PT 11.3.2 & 2019.6 last version
Logic Pro X latest version
RME BabyFace Pro
Macbook Pro july 2014 2.5ghz 16gb ram 512gb SSD - OS10.14.6 - PT 2019.6 Ended here ..
RME BabyFace Pro
Old 04-26-2017, 03:01 PM
TheNeil's Avatar
TheNeil TheNeil is offline
I did wonder what was causing this! Thanks for the info.
Overall, I quite like the app manager, so don't plan on removing it, but that's definitely something that should be fixed.
Old 04-26-2017, 10:18 PM
john
John - thanks and totally aware I could delete the app, but would like Avid to fix the app and test before releasing going forward. Not asking much.
Regards,
Ned
Monkey Boy Studios
Old 04-26-2017, 10:25 PM
It's been badly designed and broken since release. I am not confident that whoever Avid outsourced this development work to has any clue what they are doing. I don't want anything here. Avid should leave it as is for all I care. As long as users can easily remove it.
Old 04-26-2017, 10:51 PM
clausiii's Avatar
clausiii clausiii is offline
Yes, this happens here too, randomly.
My ears! My ears!
clausiii
MacBook Pro i7 Quad 2.6GHz 16GB RAM
ProTools 2020.11
Avid S1
Avid Dock
Avid Control
Digidesign Command|8
macOS Catalina
MOTU 4pre
MOTU Track16
Axiom Pro 25
LinnStrument 128
Roli Seaboard Block
tons of stomp boxes
tube amps
guitars
noise
Old 04-26-2017, 10:59 PM
JFreak's Avatar
JFreak JFreak is online now
I think it must have something to do with automatic installs, because once I turned that off Terminal stopped poppihg up
Janne
Old 04-27-2017, 08:02 AM
hi Ned, this does not uninstall the App ... just stops it from launching on startup / restart .. this way the terminal should not come up and you can still use the App Mn if you like .. Q; if you toss the Launch agent file does the Terminal still come up when you launch App Man manually ???
cheers john
RME BabyFace Pro
RME BabyFace Pro
Old 04-27-2017, 08:04 AM
thanos4 thanos4 is offline
This is also happening to me from time to time
10.12.4 here
Old 04-27-2017, 08:51 AM
midnightrambler midnightrambler is offline
10.12.4 here
Same here also
Avid Application Manager Jperkins Pro Tools 12 2 06-29-2016 10:17 PM
AVID Application Manager Ray JB Licensing & Accounts 1 04-28-2016 02:38 PM
Avid Application Manager - New Install YYR123 Pro Tools 12 4 10-30-2015 06:18 AM
