Old 01-10-2017, 12:44 PM
XJENSEN XJENSEN is offline
Default Instrument Track Commit results in huge audio delay
Is anyone else experiencing this in Protools 12.7 HD?
I'm having problems with the Track Commit feature on instrument tracks. The committed audio is completely out of sync (way too late) when committing external instruments.
It seems ADC (Automatic Delay Compensation) can't deal with this scenario?
File Type: jpg Comitted instrument track audio lag.jpg (58.4 KB, 0 views)
Old 01-10-2017, 01:12 PM
metalmixer metalmixer is offline
Default Re: Instrument Track Commit results in huge audio delay
It works here no problems I would disable all the session plug-ins and test it again
Old 01-10-2017, 01:29 PM
john1192 john1192 is offline
do you have any Plugins on your Master Fader ??
Mac Pro 6-core 3.33ghz (2012) 24gb ram 256gb SSD -OS 10.12.6 for PT 11.3.2 & 2019.6 last version
Logic Pro X latest version
RME BabyFace Pro
Macbook Pro july 2014 2.5ghz 16gb ram 512gb SSD - OS10.14.6 - PT 2019.6 Ended here ..
RME BabyFace Pro
Old 01-10-2017, 01:34 PM
Euhm, first of all, there are no active plugins in this session. Secondly, based on your comment, I don't think you understand the sense of the Commit feature. This feature is exactly meant to commit tracks *having* plugins on them, to free up processing resources or for easier session sharing. Please refer to page 939 of the Protools 12.7 manual if you like to learn more about the commit, freeze and bounce functionality.
Old 01-10-2017, 01:35 PM
No, there are no active plugins on the master fader (only a few deactivated ones).
Old 01-10-2017, 02:03 PM
DetroitT's Avatar
DetroitT DetroitT is offline
Hi just tried the DB-33(+104 samples) and Omnisphere V1 (+192 samples=acceptable Air)) Commit from clip and commit from instrument track. Both aligned well.
PT's HD12.7 Mac OS 10.12.2 DC on @ 44.1KHz 32 bit-float
What Instruments are you using or are there additional plug-ins?
Commit up to...
Further testing seems to indicate DC is indeed working here.
Added Waves XNoise stereo (5120 sample-delay)
No Delay Comp =(5239 samples at tabed peak)
DC On = 192 samples at tabbed peak.
(Help us Help You)<<<click here
APFS 90% 10% Audio on Both.
Pro Tools U-2020.5 macOS 10.14.6 APFS
Second boot-macOS 10.13.6 (Avid HDX-1 Omni)
(2k10MP 5,1 / 64-Gb)
(Sapphire RX-580 MVC-Edition-dual mini 6 pin. one spliced to add Avid mini 4 pin-hdx)
FW-CoreAudio (for poly-recording)
(SSL-HUI-MIDIoverIP)
music-design-creation
Post Music-Sound mixing, Production-Enhancements.
Audio Tuning and System Services
new systems builds / upkeep / +
New builds:
12 core nMP HDX 1 Slot 5 stock HDX Mac mini 6pin to 4 pin HDX power like 5,1 mp's used)
16 core nMP rack-test station
28 just because machine
Old 01-10-2017, 02:37 PM
Hi DetroitT,
Mind this issue is dealing with external instruments. Internally, it's also working fine here!
Old 01-10-2017, 03:23 PM
Indeed, with external instruments, all timing bets are off, but your playback buffer size might be adding to the latency. On my rig(at a 64 buffer), all the VI tracks I have committed or frozen(doing a lot of testing for just this reason, I am finding that frozen and committed audio is almost NEVER sample-accurate with the original midi note placement. Having said that, in listening tests the timing has sounded fine with offsets of anywhere from 2 to 100 samples of offset. Whether you can hear/perceive any timing issues will be a personal thing as some folks are more or less bothered by this(I find it to be no different than the same player, playing a part twice. Nobody every hits every note at the exact same sample in the timeline
Since Avid seems to be dragging their feet on fixing this, if the offset shown in the screen capture is consistent, I would measure, write it on a Post-it, stick that to the edge of the screen and nudge things into alignment(after a few times, it will become second nature)
Old 01-10-2017, 03:32 PM
lesbrunn's Avatar
lesbrunn lesbrunn is offline
Hi XJENSEN,
PT has never worked well for me with external instruments. I always have to compensate manually with midi offset, sometimes very drastically. ADC doesn't work in scenarios like that.
X99 | i7 5960x @4.6GHz | 64GB GSkill DDR4 | Nvidia GTX 950 | Samsung 950 Pro NVMe 256GB | Samsung SM961 NVMe 1TB | Samsung 850 EVO 1TB | Samsung MZ7PD256 SSD 256GB | Kingston 120GB SSD | WD Black 1TB x2 | G-Drive 4TB x2 | WD Elements 4TB | Audient ID14 | PT2020.5 | Windows 10 Pro
Old 01-10-2017, 04:03 PM
do you have your midi offset setup in Pref's ?? just trying to think of things that could cause this with ADC turned on .. please just disregard or ignore this if off base .. you cannot hurt my feelings
RME BabyFace Pro
RME BabyFace Pro
Automatic Delay Compensation - PT 12.4 - Instrument Track bug swfeathers Pro Tools 12 8 09-04-2018 09:27 AM
Pro Tools crashes trying to Commit an instrument track Rewired with Reason mrbenjaminspeed Pro Tools 12 4 04-30-2017 01:21 PM
How to set up delay right in instrument track Natanel Arnson Pro Tools 11 2 12-20-2016 06:54 PM
11.2.1: Instrument Track delay compensation problem rainsong Pro Tools 11 14 08-20-2014 03:43 PM
strange message when trying to commit to an elastic audio track gibsy General Discussion 2 12-19-2013 03:07 AM
