Old 12-05-2016, 08:21 AM
Tim Ripley's Avatar
Tim Ripley Tim Ripley is offline
Default Midi through delay with hardware synths *SOLVED!*
SOLVED!
Look later in this thread for the bold red text for the workaround/solution.
Please don't comment on this thread if you don't use hardware synths and the midi thru function in Pro Tools.
I am getting a delay that is large enough to make it difficult to play quick passages on the piano or any percussion. I have tried three different interfaces and they all have the same delay with Pro Tools. All three interfaces work perfectly with Digital Performer with no perceived delay. I am not monitoring the output of the synths in Pro tools at all. The synths are monitored directly from the console. I've been doing this for 30 years with Digital Performer. No audio is being run through Pro Tools - just the midi information on the way to the synth. The delay goes away if I open the dialog box for playback engine and change ANY setting but, when I exit the dialog box, the day returns immediately. I have no plugins running in Pro Tools and only one track in the session. I've seen others post about this problem but I've not seen any solutions - just a bunch of guys talking about VI's, keeping the buffer setting low, and not running effects on the master bus. This has nothing to do with any of that.
Timothy Ripley
Composer, engineer, musician
Mac Pro (Late 2013)
3.5 GHz 6-Core Intel Xeon E5
32 GB 1866 MHz DDR3
AMD FirePro D500 3072 MB
Dual 4Tb Thunderbolt G Drives
Acer B326HUL 32" 2560 X 1440, VIZIO video monitor
Sierra 10.13.2, Pro Tools 18.1.0.241, EuControl 18.3.0.244
Lots of WAVES Plugins, Avid Artist Mix and Control
Digital Performer 9.51, MOTU 1248 (Thunderbolt), MOTU 2408 MkII (x2)
MOTU MTP AV (USB), a bunch of hardware synths, mic preamps, & outboard FX
Old 12-06-2016, 10:48 PM
Base12 Base12 is offline
Default Re: Midi through delay with hardware synths
I use 95% 1980s hardware synths/drums. I have sync issues many times and the only section where I can correct this is in PT menu, go to Setup/Preference/MIDI, then in the field Global MIDI Playback offset wither enter a positive or negative number such as -400 or 400, then playback your drum machine and recorded midi notes/audio. Play with the numbers.
Also, in the Menu-> Options, try Delay Compensation on or off. Its a trial and error but once you find the number for the gear, it syncs up fine.
Old 12-07-2016, 03:30 AM
ChuckS ChuckS is offline
This delay with outboard gear seems to be tied to the audio buffer size. I find the bigger the buffer the longer the delay. Not quite sure why they would adjust the MIDI timing like this for outboard MIDI thru. I haven't experienced this in other DAWs.
PT 2020.5 DP 10.11 VEP 7.x MOTU M4 HP Envy 8G i7 Quad Laptop Win10 (x64 20H2)
PT 2020.5 DP 10.11 VEP 7.x 828mkII ADA8200 MTP-AV 2011 Mac Mini i7 Quad High Sierra.6
Old 12-07-2016, 06:32 PM
Tim Ripley's Avatar
This has nothing to do with playback or sync. It has to do with the delay while trying to play the synths live.
Timothy Ripley
Mac Pro (Late 2013)
32 GB 1866 MHz DDR3
Old 12-07-2016, 06:33 PM
Tim Ripley's Avatar
I get exactly the same delay no matter where the buffer is set.
Timothy Ripley
Mac Pro (Late 2013)
32 GB 1866 MHz DDR3
Old 12-07-2016, 06:47 PM
Blinkofani Blinkofani is offline
I have no delay when playing ext. synth. Here's my setup: I select a midi track and the audio is coming back in PT through an audio track that I leave on input monitoring("I" button). In Options, Midi thru and Delay Compensation are ticked. Buffer is at 256. Hope it helps.
Blink
iMac 27" i5 w/24Gb ram, macOS 10.14.6, PT 2019.10 Vanilla, Logic Pro X 10.5, UA Arrow, UAD2 Satellite Quad TB, LaCie ext. SSD, Genelec 8040a, Dave Smith Mopho, Korg Z1ex, Gibson Les Paul Classic, Fender Telecaster & Stratocaster, Komplete 12, Omnisphere 1.5, Korg Legacy Coll., Arturia Moog Modular and Prophet.
Old 12-07-2016, 09:09 PM
Tim Ripley's Avatar
Blink
I don't monitor the synths in pro tools, and the buffer has no effect on the delay whether it's set to minimum or maximum. The only thing going through pro tools is the MIDI. What MIDI interface and controller are you using?
Timothy Ripley
Mac Pro (Late 2013)
32 GB 1866 MHz DDR3
Old 12-08-2016, 04:46 AM
Korg Z1 going in a Cakewalk UM-1g, sending Midi to a Dave Smith Mopho and Korg Wavestation...
Blink
Old 12-08-2016, 06:11 AM
Blink
Just for grins - if you bump up your buffer to 1024 is a delay introduced? The OP and I are using the same MIDI interface, so there might be something there.
Old 12-08-2016, 10:14 AM
chroma17 chroma17 is offline
Have you tried un-checking "MIDI Notes and Controllers" under the "Delay Compensation for External Devices" heading in the MIDI preferences? This can effect MIDI being routed through Pro Tools even if you are not recording.
I only have a slight delay (around 10ms) sending MIDI via an RME AIO PCIe card.
Any Of You Still Using Hardware Synths With Your PT Setup? epu 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 7 10-04-2010 06:51 AM
hardware synths or virt synths help!! djmichael.london 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 08-22-2008 12:59 PM
Soft Synths and Delay Compensation michael c Pro Tools TDM Systems (Mac) 1 02-20-2006 10:22 AM
triggering MPC and hardware synths djecity Tips & Tricks 1 08-19-2005 01:41 AM
midi delay and soft synths soosh Digidesign Hardware & Software 1 01-24-2001 07:24 PM
