Old 11-23-2016, 12:01 AM
LSinBTonez LSinBTonez is offline
Default Rendered freeze files in Pro Tools 12.6
Hey, I'm still new to Pro Tools. I wanted to know if there was a way to get pro tools to automatically delete the freeze files from the Rendered Files folder after unfreezing. I've looked in the manual and nothing about that was stated.
Old 11-23-2016, 04:10 AM
Drew Mazurek's Avatar
Default Re: Rendered freeze files in Pro Tools 12.6
PT should "clean up" after itself when you close the session.
www.drewmazurek.com
Old 11-23-2016, 04:41 AM
I just tested it again, the freeze file still remained. This is what I did to test it...
1. Froze a track then saved and closed the session.
2. Opened the session back up unfroze the track then saved and closed the session.
Then I checked the Session folder, it was still there.
Old 11-23-2016, 04:47 AM
Shouldn't happen.
Log it as a bug on http://protools.ideascale.com if you like.
www.drewmazurek.com
Old 11-23-2016, 04:48 AM
Thanks, will do now. I'm not trying to waste storage space.
Old 11-23-2016, 05:06 AM
I logged it with Avid internally as well.
www.drewmazurek.com
Old 11-23-2016, 11:39 AM
Carl Kolchak Carl Kolchak is offline
I thought the fact that Pro Tools keeps all the frozen files is a feature, rather than a bug.
It's handy to have the various iterations of any frozen file, you never know when you may need to revert back to a previously frozen version - particularly when collaborating (you can send a specific rendered version to someone, who may not even be a Pro Tools user, carry on working on the unfrozen track, and still go back to an earlier frozen state if needed), or if you are using a modulation effect which is random in it's nature, and one particular freeze was more satisfying than subsequent others).
Each time a file is frozen, it is given a unique ID, but it's up to the user to log the takes.
Then again, it could be a bug...
Personally, when I come to archive a session, I go the "Save Copy In" route, and omit / clear out all the redundant data, which would take care of this issue.
The only trouble is, these days it's becoming the norm for a session to never be truly finished with - there always seem to be revisions somehow - so it's harder to get rid of the bloat, because you never know if it will eventually be required.
Old 11-23-2016, 11:42 AM
Bug for sure.
What you're describing is what Commit is for.
www.drewmazurek.com
Old 11-23-2016, 11:44 AM
I mainly use freeze if I'm heavy into mixing and I have to record some more tracks. And being that its rendering 32bit files that adds up pretty quick to just sit there.
Old 11-23-2016, 12:39 PM
Originally Posted by Drew Mazurek View Post
Bug for sure.
Good to know - I thought it odd initially, but saw the usefulness.
Sure, except it actually works as a version log for freeze - I often find that even though I've progressed through a composition / mix, there are reasons that I want to go back to an earlier version of a frozen track (temporarily, or just for reference).
The advantage of Freeze, and the benefit of the stored rendered files, is that I don't have Commit creating new tracks - I can use the original tracks, and playlists.
Missing Rendered Elastic Files Electric Peak Pro Tools 10 10 10-18-2019 10:37 AM
Rendered Frozen Files Missing Jon_Atkinson Pro Tools 12 8 08-24-2018 10:00 PM
Rendered Files : WHERE do they disappear to? midnightrambler Pro Tools HDX & HD Native Systems (Mac) 1 12-18-2012 07:42 AM
Can't find rendered files RobPG 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 07-02-2009 11:58 PM
Squeaky Noises Rendered in Fade Files toddburke Pro Tools TDM Systems (Mac) 5 01-20-2004 09:34 PM
