Old 09-29-2016, 08:36 PM
moshuajusic moshuajusic is offline
Default Toggle bypass between 2 plugins?
I want to compare 2 comp plugins on 1 track. Right now I bypass one, then un-bypass the other. And repeat. But it'd be way better if bypassing 1 would automatically un-bypass the other, and vice versa, so I can hear the difference immediately. Is this possible?
Old 09-29-2016, 08:46 PM
Top Jimmy's Avatar
Duplicate the track and put one comp on one and the other comp on the other. Mute one track. Put the two tracks in a mix group. Clicking either mute will toggle which track is muted. Once you've made your choice, ungroup and delete the losing track.
James Cadwallader
Hackintosh - Gigabyte Z77X-UP5TH, Intel Core i7-3770K, 32GB 1600Mhz DDR3, 2x SATA 6Gb/s 240GB SSD, 3x SATA 6Gb/s 1TB HDD, 1x Glyph 2TB USB3 HDD, Mojave 10.14.6.
Pro Tools Ultimate 2021.3, HD Native, Focusrite Red 8Pre (Mac)
Pro Tools 2020.12, Mbox3 (Win)
Old 09-29-2016, 09:13 PM
Default Re: Toggle bypass between 2 plugins?
I was hoping for something more direct & efficient. There should be a key/click or something in the popup menu to link the bypass of multiple plugins on a track. Then you just command-click 1 to automatically bypass the others. (And vice versa.) They could even implement a way to "lock" a plugin so you can audition multiple comp plugins while leaving the EQ plugin active, for example. (Yeah, you could "freeze" or print the audio with just the EQ, and then do the duplicate/group/mute/ungroup/delete duplicate thing, but that's horribly inefficient.) Off to ideascale...
Old 09-29-2016, 11:11 PM
Seafoam_Green's Avatar
Seafoam_Green Seafoam_Green is offline
Get yourself NUGEN A-B Assist .., it s should free to download directly from your AVID account..., http://connect.avid.com/NUGEN-Audio-...-download.html
if not go to the Nugen website ; https://www.nugenaudio.com/newsitem....c-001999c29f76
See it in action here ; https://youtu.be/jToWV-6IZns
note - you-tube also has installation and authorisation videos available
Pro Tools 2021.6.0 Native * Slate Raven MTi-1 Version 3.9.1 * AVID MBox3 Pro * OSX Mojave 10.14.6 * MAC PRO (late 2013) * 3.0 GHz 10-Core Intel Xeon E5 * 64 GB Ram 1866 MHz DDR * AMD FirePro D700 6GB * Lacie LBD 1TB Thunderbolt 2 PCiE * Blackmagic Multidock Thunderbolt2 * Samsung SSD's 850 Pro * WD Black HDD's
Old 09-30-2016, 01:59 PM
http://protools.ideascale.com/a/dtd/...ns/250272-3779
Vote up!
Thanks for the info, but that looks more roundabout than Top Jimmy's solution.
Is there a key command to toggle a plug in's bypass? Captain Audio Pro Tools TDM Systems (Mac) 2 04-30-2018 03:25 PM
Bypass Channel Plugins sincap Tips & Tricks 7 03-07-2018 05:42 PM
Plugins & Memory ~ BYPASS Zoduati 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 6 11-04-2012 07:31 AM
Bypass all plugins Assi 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 3 07-04-2008 05:06 AM
How to hard bypass plugins in XP? lifer Pro Tools TDM Systems (Win) 4 02-07-2006 03:44 PM
