Old 09-19-2016, 12:32 PM
hammerfied hammerfied is offline
Default Digi002 works on Mac, not on Windows. ANOTHER Digi002 works on both
Here's the issue. I have two Digi002
Digi002 A works on both Mac (El Cap) and Windows 10 w/Pro Tools 10
Digi002 B works on same Mac (El Cap) but does NOT work on the same Windows 10 w/Pro Tools 10
Same everything!
Windows 10 is using a Firewire card.
I've tried disabling, re-enabling the card.
I've tried re-installing the Digi002 drivers with the Digi002 B plugged in.
Nada. Anyone ever seen anything like that before?
Old 09-20-2016, 09:59 AM
Default Re: Digi002 works on Mac, not on Windows. ANOTHER Digi002 works on both
Just in case....NEVER hot-patch the firewire cable In any case, it doesn't seem to make sense to me either(assuming you use the same FW cable in all cases)
Old 09-20-2016, 01:00 PM
Doesn't make sense to you and me both! Same cable. I plug both Digi002s into the Mac and Windows machines separately, both work like a dream. Turn them off, switch the cables in back of the Digi002s: dead on the Windows 10 machine, Mac works. The Device manager doesn't even list it.
All kinds of restarts, re-installs, etc. Nothing. Swapped cables a couple times. Same.
Old 09-20-2016, 02:38 PM
Only thing I can think of is; maybe 1 has different firmware? Not that this SHOULD work, but you could try the other firewire drivers in the Windows machine. When I had my 003, on Win7, there were 3 resident FW drivers available(using the "Let me choose from a list" option). The Legacy driver(Avid-recommended) never worked. The TI Compliant driver worked great. The 3rd option(I can't remember) actually turned the 003 surface into a big Midi Note generator(hit a mute button, get a hihat sound from EZdrummer)
Mbox 2, Input works, sound for non-protools works... rmiller9969 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 7 08-13-2011 04:13 PM
7.4 works, 8.0.4 has audio crackle (digi002) JJ_Voice 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 13 11-17-2010 03:14 PM
Intel P4 for DIGI002 System That Works Antonio Tarantino 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 0 03-20-2003 05:48 PM
It Works! My Protools system works!!! Woooooo Hooooo!! Siberian 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 8 03-19-2003 08:48 AM
TC Works for PT HD Windows wolftone Pro Tools TDM Systems (Win) 1 08-12-2002 09:58 AM
