Go Back   Avid Pro Audio Community > Pro Mixing > Pro Tools | Dock
Old 09-06-2016, 09:25 AM
spoons's Avatar
spoons spoons is offline
Default Soft Keys
This is specific to the soft keys directly under the iPad on the dock only.
When I perform certain functions like for example "commit track", "delete track" or even just tabbing away from ProTools to say Safari, the soft keys become focussed away and do not function. To refocus them I have to hit the "Soft Keys" button on the dock twice each time.
I have locked Eucon to ProTools under Assign. I'm on Mavericks with the latest version of Eucon and ProTools.
I am using an iPad 2 so this may be the reason?
Anybody else seeing this ?
Richard Spooner
www.spoonsound.com
Old 09-06-2016, 02:20 PM
bobbyguelz bobbyguelz is offline
Default Re: Soft Keys
I have the EXACT same issue... Again... another dumb issue that makes something that is supposed to be helpful... SOOO NOT helpful.
I've used it with the iPad 2... but also with the iPad Air 2. I believe I had the same issue with both... but can't confirm till I'm back at the studio.
Old 09-06-2016, 10:41 PM
WorldStudios WorldStudios is offline
This is avoided if you lock the control surface (Dock) to ProTools. It is easy to do under the "Assign" tab in the Eucon app. I lock the entire surface to ProTools, so I can stop and play PT while posting on the DUC, for instance.
Johan Bejerholm
World Studios
Sweden
Phone +46707773443
Old 09-07-2016, 04:07 AM
Ok... Fantastic to know. Will certainly be doing just that then. Thanks again!
Old 09-07-2016, 04:02 PM
spoons's Avatar
As I said above, i have the app locked to protools under Assign. The problem is still as described above and is specific to the soft keys only.
Richard Spooner
www.spoonsound.com
Old 09-07-2016, 07:24 PM
docric docric is offline
Same here, Spoons... same prob & surface is locked to PT.
I just click away & click back, like you do.
It would be nice if it worked correctly, though.
-C' ya'
Rick
MacPro Quad core, OSX 10.10.5
PT 12.5.2/HDX
Burl MS / PT Dock/ Eucon 3.4.1/iPad Air2/ iOS 9.3.5/ProTools|Control
Old 09-16-2016, 12:29 PM
AssemblyLineKevin AssemblyLineKevin is offline
Hello all, I am new here, but have been a full time ProTools user since 1999.
I recently retired my ProControl, went to Artist series and Artist Mix. Did not care for them. Landed on Dock and S3.
****I am having the SAME issue. Soft keys "go away" and have to be clicked to be reset. Very annoying.****
As with others here I am locked to ProTools, have not found a work around this issue. Seems to be a bug. Would be nice if it were fixed.
Thank you all if anyone finds a solution. Cheers!
Old 09-23-2016, 02:27 AM
spoons's Avatar
So now after upgrading to the latest version of EuCon I have another 'button' issue. This time the 'Alt" automation key. Sometimes even with it's lit the alt automation functions aren't working. I have to hit it twice to 'wake it up'.
I haven't been able to work out what makes it do this as it's not all the time. The most annoying is when you are in preview already and it's lost 'focus'. Hitting punch preview and then All/Sel doesn't work and you've lost what you were doing.
With this and the problem above I'm finding myself migrate back to the keyboard again.
Richard Spooner
www.spoonsound.com
Old 09-25-2016, 06:46 AM
spoons's Avatar
The above behaviour is happening every time I tab out of protools to another program. Again I have Eucon locked to protools.
Richard Spooner
www.spoonsound.com
Old 09-26-2016, 01:47 AM
bassmagnetic bassmagnetic is offline
Hi Richard,
Yep, I have same behaviour and its been confirmed as a reproducible bug and its logged with Avid, I'm hoping fixed in next update as its a bit confusing!
Soft Keys gone after upgrade spoons Pro Tools | Dock 1 08-31-2016 11:39 AM
Looking For an Old Soft Keys File (v1.4) Dan Smith Pro Tools | S6 5 04-11-2016 05:52 PM
Why no Soft Keys on S3? jacko Pro Tools | S3 15 02-09-2016 08:43 PM
Soft Keys 9-16 not working. J-S-Q Pro Tools | S3 2 05-19-2015 01:51 AM
Soft Keys marrap Artist Series 4 11-28-2011 09:17 AM
