Old 04-12-2016, 03:38 AM
mj77's Avatar
mj77 mj77 is offline
Default PT 12.5, WIN 10 : mfc120u.dll cannot be loaded
Hello
I have tried to install PT 12.5 on Windows 10 PRO 64 bit , everything went OK except when Running PT I had the following message : "import DLL mfc120u.dll cannot be loaded ..." , and PT won't run.
The Solution : Go to Microsoft.com and search for Visual C++ Redistributable Packages for Visual Studio 2013 , choose the right file for your system (i guess only the one with 64bit for PT 12) and install it , then PT12.5 runs well
Note : I haven't yet checked PT's 12.5 stability .
Good Luck
Music keeps me alive
Old 04-15-2016, 09:27 PM
Mizzen1 Mizzen1 is offline
Default Re: PT 12.5, WIN 10 : mfc120u.dll cannot be loaded
I am having the same issue. Pro Tools 12.5 HD was working fine, and suddenly I started getting the "import DLL mfc120u.dll cannot be loaded ..." , and PT would not run. However, Mj77's solution did not work for me. I tried installing both the 2013 and 2015 versions of the C++ with no change in the Pro Tools failure.
Any ideas?
As an update, I did a repair installation on Pro Tools 12.5 HD through Control Panel, then rebooted, then installed the 2015 C++ again (Pro Tools still not working), then installed the 2013 version of C++ again (and incidentally, also installed an updated version of the eLicenser manager software), and voila! Pro Tools 12.5 HD is working again.
Old 04-18-2016, 01:48 PM
Ric52 Ric52 is offline
I had the same problem, only I went into Windows uninstaller and there was an option to repair the C++ files in question. I also did an internet search for the *.dll file ( mine was msvp120.dll missing or couldn't load.
Hope this helps
Old 11-04-2016, 08:16 AM
ouibjamn ouibjamn is offline
Wow. THANK YOU so much for this!
This problem randomly appeared today and updating C++ fixed it.
Old 03-23-2018, 06:43 AM
Kirby B. Kirby B. is offline
repairing all those C++ things did it for me too! grateful for this idea! Thanks!
Digi002R PT2018 Win 10
INTEL Core i7 930, 3.52 Ghz
GIGABYTE GA-X58A-UD3R
CORSAIR XMS3 12GB 1600Mhz
2 X WD 1TB Caviar Black 64 GB cache
MOTU Traveller PT2018
MacBook Pro Mojave
16GB DDR3
'DAE Loaded' RobsDream Pro Tools SE and Essential (Mac) 0 05-01-2013 12:24 PM
How to see what kit is loaded in Strike tooold Virtual Instruments 6 04-30-2013 08:58 AM
003 DAE Loaded Freeze chasebasolo 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 0 12-04-2011 02:05 PM
DAE Loaded hangs dmichael Windows 0 07-13-2011 10:54 AM
"DAE LOADED" problem gwell1 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 03-29-2006 05:43 AM
