Old 04-10-2016, 12:29 PM
TrentWilliams TrentWilliams is offline
Default Change region, but keep all automation?
Hello,
I'm working on a simple atmosphere design at the minute. I have been asked to include a distant radio.
So I used a generic music track and automated: volume, clip gain, pan, Altiverb plugin, Binauralizer plugin, Speakerphone plugin, and two instances of a 1-Band EQ plugin. The result I achieved was really good, and am genuinely happy.
However, the client has asked to change the song.
Is there any way I can replace the region, but keep all of my automation?
Any help is appreciated,
- Trent
Pro Tools 2019.6|Ultimate, UAD Apollo 8, UAD Octo+Quad Satellite, UAD Apollo Twin Quad Core, Focusrite 8PreXiMac 27" Late 2013 - 3.5GHz i7 - macOS 10.14.4 • RAM 32GB DDR3, GPU NVidia GTX 780M 4GB
Old 04-11-2016, 04:20 AM
JFreak's Avatar
JFreak JFreak is offline
Default Re: Change region, but keep all automation?
Does this work for you?
Janne
Old 04-11-2016, 05:00 AM
joachim's Avatar
joachim joachim is offline
The clip gain might be coalesced to volume automation first, otherwise it will get lost in the replacement process.
Another way :
duplicate the original track, without the playlists (just to get the same plugins and the automation)
drag the new song from the clip list onto the duplicated track, align in time with the original (recheck the automation)
original track : copy special clip gain - move edit selection down to the duplicated track - paste clip gain.
The automation should be the same, otherwise : copy special all automation from the original track - repeat to fill on the duplicate track.
The original track thereafter: I would make it hide and inactive, the client might change his mind again ... .
PT 11.3.2 HD , RME Fireface 800 , Genelec 5.1 ,
Win7 64bit Professional , i7 3930 Hexcore , 48GB Ram , SSD System + SSD PT Session/Audio + SSD Video (all Samsung 840 Evo) + Spinner 1TB Data , 2x Radeon HD 5450 \\ SD 633 Femto MKH8060 MKH8070 MKH30/MKH40 DPA4060
Old 04-11-2016, 05:07 AM
amagras amagras is offline
Interesting. I don't know for sure but having "automation follows edit" off might be of help...or not. Will try what J proposed to see if it works with non HD as one of the comments says it's only HD feature.
Dell XPS 8700. Intel Core i7-4770 CPU @ 3.40GHz. RAM: 16GB. Windows 10 Home x64. NVIDIA GeForce GTX 645. NI Komplete Audio 6. Pro Tools Software 2019
amagrasmusic.com
Old 04-18-2016, 02:12 PM
DJ Hellfire DJ Hellfire is offline
Make a duplicate of the track. Replace the audio, then paste all the automation back on the track.
www.HellfireBeats.com
Akai MPC 2000XL, Akai MPC X, Mackie 1202VLZ Pro, Akai Advance 61, Focal Alpha 80, UAD 2 Apollo Quad, UAD 2 Satellite Quad, UAD 2 Octo PCIe, Neve R6 "Lunch Box", Neve Portico 511, Neve Portico 551, Neumann TLM49
Pro Tools 2018.10
Mac Pro 4,1 (5,1 upgrade), Early-2009, 3.46GHz Nehalem 12-Core, 32GB RAM - OS 10.12.6
13" MacBook Pro, Late-2011, 2.4GHz Dual Core i5, 16GB RAM - OS 10.12.6
27" iMac, Late-2012, 3.4GHz i7, 24GB RAM - OS 10.12.6
Old 04-25-2016, 04:15 AM
yoerik roevens yoerik roevens is offline
indeed, turn 'automation follows edit' off and drag/spot the new auto on top of the old one
Export region list keep tempo change? bryced87 macOS 0 05-18-2014 03:55 PM
Pro Tools 11 region selection not moving with tempo change Skytouch Pro Tools 11 0 12-22-2013 12:12 AM
Does Editing Source Region Change Subsequent Loops? Zep Dude Pro Tools TDM Systems (Mac) 4 09-24-2007 10:04 PM
Audio region behaviour on tempo change moqtev Tips & Tricks 1 11-13-2006 01:08 PM
stretching an audio region to change the tempo - is it possible? Joseph Grimm 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 5 10-12-2000 10:27 AM
